glovebox removal??
Trig
I don't have a top one but the lower has a couple of screws at the top and a couple of bolts at the bottom if memory serves me right, it's been a while. All very obviously once you look at it, a torch and a bendy neck might be needed though :)
I'm not sure if J-Spec cars without an airbag will still have the wiring for one but if they do it's attached to the top of the glovebox so be careful when you lower it out.
Once you've got the bottom one off( as above), look up into the hole and you will see 2 gold coloured screws. undo them, then open the top glovebox and prise off the plastic caps at the back and undo the two more gold screws. Then you have to pull up the top glovebox from the front so the hinge will clear the dash.
