Rear wheel bearing
wkdtime
My rear n/s wheel bearing is fooked, the wheel has alot of play and also makes a metal rubbing nose when driving which gets louder as the car accelerates also the car feels very unstable and the rear wobbles (combination of fooked shocks and bearing i think).
So my question is do i need to just order the wheel bearing or is there something else that i should order as the wheel has alot of play in it.
First thing to do is strip down the hub to investigate the causes of the free play. It probably is just the bearing but it could be more. Driving the car will only make matters worse, avoid it if possible.
Its going to go into Phoneix within the next month, car is parked up. I just thought id try and get everything first prior to taking it there as its getting quite a bit of work done.
You will also need to buy the inner and outer oil seals as well, i don't think they come with it.
That is correct Colin, the inner and outer seals do not come with the bearings, so they will need to be ordered seperately.
