cntt Posted August 18, 2006 Share Posted August 18, 2006 will the TT M/T clutch fits the NA M/T? someone told me the 6sp box uses different clutch, is that true, how would the tranny make a different on the clutch since the clutch is mounted on the flywheel which is on the engine side!?! I need to replace my clutch, as it is shuttering at take off when it is warmed up, and I can't drop down the gear when it gets up the speed, cruising through town at 30mph I will have no problem through any gears, but out on the open road, doing higher speed, can't go down the gear, have to wait till it gets to below 40mph before it will go in to 4th from 5th, had that problem before with a honda and the clutch was in bits when I had it out! just want to check first to see what clutch I should get, since I'm not going to go N/A-T for atleast another year and also will be going 6sp, no point spending a lot of money on this replacement if it wont be use when times comes! cheers Quote Link to comment Share on other sites More sharing options...
