what boost?
richy2jz-gte
im running a standard (apart from full decat and super dragger) uk tt but im not sure what sort of boost the car should be running its running about 0.7 bar, does this sound right. and im also thinking of fitting a blitz boost controller will both the turbos boost what ever its set 2 or just no2?
I've heard that UK specs don't go as mental as the J-specs do when decatted but nonetheless I'd expect a larger amount of boost than that. Where have you t'd in your turbo pressure reference, and also check your exhaust for silencer material in case that's come loose and is bunging it all up.
The boost controller sets the overall boost pressure level, don't let the fact that there are two turbo's confuse you :)
-Ian
