car wont start
Hippium
Hi all
I turn the ignition, theres a 'clattering' noise (sounds electrical) lights flicker with the clatter, the starter doesnt seem to engage.
Any clues?
Only thing I did recently, short of driving it back from being repaired was look under the drivers side foot well, just finding out whats what, I took the cover off the fuse box down there & replaced it.
I'm guessing its something to do with the immobiliser but that all seems to function as it should - its an apollo 2002 if that helps...
Well, it did'nt blow up but what it did do was... not very much...
Couldnt swap the battery out as the terminals on the other battery were too large so I tried jumping it from a hefty two-battery diesel van with no effect.
The internal door lights got dimmer & dimmer & the beeping sound from the ignition & immobiliser got higher pitched as the power went - this was whilst trying to jump it, I have to say.
I'm stumped but then, I dont profess to know much about cars...
Thanks SUPRALOOPY
before I go shelling out for a new battery, I thought I'd better test the charge with a multimeter, it read 3.4 volts which is a bit off compared to 12.9 on the other car here, since it didnt jump could it be flat, could it be a dead cell...?
Thanks SUPRALOOPY
i'd say definitely new battery time. Were you using a decent size jump lead or those cheap thin things?
yeah Terrible, the electrolyte levels were fine, just over the plates in all compartments, I put some more ionised water in to be sure (not much)
LeeT, the jump leads seemed pretty thick (what do I know) to me, about a cm
SUPRALOOPY a 4 year one, I take it thats how long its likely to last rather than a brand, speaking of which,
LeeT Halfords HCB005? is that the best I can hope to get & its from Halfords? Plus, is it worth getting a sealed gel battery coz I'm lazy or are they inneficient in other ways?
Thanks all for your replies, feeling like I'm taking more than I'm giving to the forum at the mo, hopefully my turn will come... :)
4 Years is the garauntee. cm jump leads are shit..halfrauds batterys are fine as long as they are garaunteed;) Most batterys are maintenance free now so don't worrie:D If all else fails then i have a gallon of petrol and a box of matches going cheap;) :p
lmao, thanks SUPRALOOPY, keep the matches in reserve
I'll get down to halfords for the battery & maybe some leads tomorrow (today?), later...
I'll let people know on here if this sorts it or if its anything more interesting :)
  • 1 month later...
