imi Posted August 5, 2006 Share Posted August 5, 2006 Hey Peeps Need some help. Yesterday while driving the car back I noticed that the clutch pedal behaving irratically. Sometimes it wouldnt come back up all the way. Sometimes when pressing the clutch, the pedal would be soft for the 1st inch of travel and then it would be ok (if that makes sense) and then it would sort itself out for a few miles... Car drives fine, doesnt seem like a slipping clutch or anything, picks up fine in 5th and 6th from low speeds... What could it be?? Link to comment Share on other sites More sharing options...
JohnA Posted August 5, 2006 Share Posted August 5, 2006 Is it very hard to bleed the supra clutch? That would be my first thought. I do it on my bikes every couple of years, along with the brakes. Link to comment Share on other sites More sharing options...
imi Posted August 5, 2006 Author Share Posted August 5, 2006 Is it very hard to bleed the supra clutch? That would be my first thought. . hmm...JohnA ASKING ME bleeding the clutch - hmm how do i do this? off to search, Link to comment Share on other sites More sharing options...
JohnA Posted August 5, 2006 Share Posted August 5, 2006 hmm...JohnA ASKING ME well yeah, I don't know your level of mechanical competence, do I? Link to comment Share on other sites More sharing options...
imi Posted August 5, 2006 Author Share Posted August 5, 2006 well yeah, I don't know your level of mechanical competence, do I? Zero would be close Link to comment Share on other sites More sharing options...
JohnK Posted August 5, 2006 Share Posted August 5, 2006 Bleeding the clutch is simple, need 2 people though, the bleed nipple is very easy to get at with the car raised onto an axel stand front near side. Just follow the clutch fluid pipe to the box, is right next to where it meets the box. Link to comment Share on other sites More sharing options...
JohnA Posted August 5, 2006 Share Posted August 5, 2006 It's dead easy even solo, if you use one of those brake-bleeding hand pumps. Very useful tool, mine can also reverses for boost (goes up to 5 bar, useful for slowly pressurising actuators etc) Link to comment Share on other sites More sharing options...
hadyn Posted August 5, 2006 Share Posted August 5, 2006 Sounds like your clutch is on its last legs mate... Link to comment Share on other sites More sharing options...
imi Posted August 5, 2006 Author Share Posted August 5, 2006 Sounds like your clutch is on its last legs mate... hmm....car pulls fine though...I drove it today without ANY problems. yesterday it was very irratic, sometimes OK, sometimes not as described. Link to comment Share on other sites More sharing options...
Mike B Posted August 5, 2006 Share Posted August 5, 2006 I had a similar problem on mine and I adjusted the cable that connects directly onto the pedal, in effect raising the bite point from close to the floor to the upper end of travel and it was fine after that. Still your problem may be totally different - just thought it was worth mentioning! Link to comment Share on other sites More sharing options...
JohnK Posted August 5, 2006 Share Posted August 5, 2006 I had a similar problem on mine and I adjusted the cable that connects directly onto the pedal, in effect raising the bite point from close to the floor to the upper end of travel and it was fine after that. Still your problem may be totally different - just thought it was worth mentioning! Cable? I was under the impression all supras had hydraulic clutches Link to comment Share on other sites More sharing options...
