Guest timalbert Posted July 31, 2006 Share Posted July 31, 2006 is there anyone who has managed to keep the active spoiler down at under 60mph? it only works with the ignition off!!! Link to comment Share on other sites More sharing options...
JODY T Posted July 31, 2006 Share Posted July 31, 2006 yeah, With ignition on, lower the spoiler, then take the fuse out.... It will stay down then...... Link to comment Share on other sites More sharing options...
JohnA Posted July 31, 2006 Share Posted July 31, 2006 The whole idea is that it's pulled up at low speeds to avoid getting hit by pavements, ramps etc. Link to comment Share on other sites More sharing options...
mr lover Posted July 31, 2006 Share Posted July 31, 2006 yeah, With ignition on, lower the spoiler, then take the fuse out.... It will stay down then...... you want to unplug it from the ecu as well or you will have warning light on Link to comment Share on other sites More sharing options...
Ruff_Rider Posted July 31, 2006 Share Posted July 31, 2006 If you have it permanently down then you should consider colour coding it to the colour of your car, along with plastic trims all round, unless you have OEM sides of course. Then it will look like you've fitted a splitter. Link to comment Share on other sites More sharing options...
mr lover Posted July 31, 2006 Share Posted July 31, 2006 If you have it permanently down then you should consider colour coding it to the colour of your car, along with plastic trims all round, unless you have OEM sides of course. Then it will look like you've fitted a splitter. like mine http://www.mkivsupra.net/vbb/vbpicgallery.php?do=big&p=2025 Link to comment Share on other sites More sharing options...
Ruff_Rider Posted July 31, 2006 Share Posted July 31, 2006 Are you going to paint the active spoiler and plastic trim? I've seen it done and it looks good. Link to comment Share on other sites More sharing options...
Mcgoo Posted August 1, 2006 Share Posted August 1, 2006 Have a look at this tread http://www.mkivsupra.net/vbb/showthread.php?t=62263 This allows you to select it up or down whenever you want with the original switch. Link to comment Share on other sites More sharing options...
Guest 2JayZ Posted August 1, 2006 Share Posted August 1, 2006 Or you could have it ripped out and put a lovely aftermarket front lip on Link to comment Share on other sites More sharing options...
imi Posted August 1, 2006 Share Posted August 1, 2006 Or you could have it ripped out and put a lovely aftermarket front lip on will you be able to lift that up like the active spoiler, for speed bumps and all...?? Seems like Toyota once again have put a lot of thought in the Supra Link to comment Share on other sites More sharing options...
Guest Garfy Posted August 1, 2006 Share Posted August 1, 2006 Have a look at this tread http://www.mkivsupra.net/vbb/showthread.php?t=62263 This allows you to select it up or down whenever you want with the original switch. It sure does, thats how I did it in the end. Link to comment Share on other sites More sharing options...
