Guest mk47 Posted July 27, 2006 Share Posted July 27, 2006 my engine ECU? ive got an apexi pencil style turbo timer and want to have a crack at fitting it, anyone done this before? any tips? is it hard? Quote Link to comment Share on other sites More sharing options...
LeeT Posted July 27, 2006 Share Posted July 27, 2006 why do you want to know where the ECU is? Just buy a plug and play harness which on most cars will just plug in behind the ignition switch. Admittedly i've never fitted one to a supra though Quote Link to comment Share on other sites More sharing options...
LeeT Posted July 27, 2006 Share Posted July 27, 2006 oh and the ECU is under the passenger footwell carpet Quote Link to comment Share on other sites More sharing options...
Ben-san Posted July 27, 2006 Share Posted July 27, 2006 Be careful down there Maz... it's a world of pain if something decides to severe(sp?). If you have to splice in, keep the main lines in tact for continuity. Then you can always remove extra gubbins without hacking too much into the loom. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 27, 2006 Share Posted July 27, 2006 seems like too much work for me to do and too much of a risk to fuck up. iv just took the dash off but i cant even see the bloody harness from the ignition switch? apparently i wouldnt need to wire it to the ecu if i dont want the feature of battery voltage etc. anyone know where the ignition switch harness is? its simple that way, jus plug the harness into the apexi, that into where the original harness goes, and ground it to the handbrake. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 27, 2006 Share Posted July 27, 2006 bump, wher do i find the ignition harness? infact how can i remove the air duct underneath the steering wheel? Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 27, 2006 Share Posted July 27, 2006 bump ^ Quote Link to comment Share on other sites More sharing options...
Ben-san Posted July 27, 2006 Share Posted July 27, 2006 infact how can i remove the air duct underneath the steering wheel? It's bendy dude. Ease it out, it's not screwed down, just wedged between two pipes. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 27, 2006 Share Posted July 27, 2006 hey thanks ben. ive finally got that out and located the damn harness, but its so hard to disconnect like its been glued on! is there any special technique to use? Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 27, 2006 Share Posted July 27, 2006 anyone know how to disconnect the ignition harness without breaking it? Quote Link to comment Share on other sites More sharing options...
