Nic Posted August 1, 2006 Share Posted August 1, 2006 hya,just to confirm then for my j spec i need to get 9005 hb3 bulbs.what do you mean when you say dipped and main beam? i take it main beam is for at night? No dip beam is the central light of the 3, high beams are the inner most lights. You need to use 9005/HB3 for the dipped beam and high beam on the J-spec lights. Correct bulbs are dipped 9006J and high 9005J, but these are not generally available, so you need to substitute both with 9005 bulbs (9006 will not fit). This is only applicable with the J-spec lights, the UK glass headlights use 9006 low and 9005 high. Link to comment Share on other sites More sharing options...
Guru Posted August 1, 2006 Share Posted August 1, 2006 So after getting remineded of this what is the best budget HID 4k kit about? Link to comment Share on other sites More sharing options...
ChrisSZ Posted August 1, 2006 Share Posted August 1, 2006 Vision Expres (on ebay) for just over a ton - very good stuff :) Link to comment Share on other sites More sharing options...
Guru Posted August 1, 2006 Share Posted August 1, 2006 Very good stuff as in perfect fit, long lasting and excellent light? Link to comment Share on other sites More sharing options...
Guru Posted August 1, 2006 Share Posted August 1, 2006 And if its the link posted previously then they don't trade anymore..... Link to comment Share on other sites More sharing options...
ChrisSZ Posted August 1, 2006 Share Posted August 1, 2006 So far I've not been able to fault them!! And yes, they do seem to have stopped trading on fleabay but their own website is still up and running http://www.visionbulbs.com/ Link to comment Share on other sites More sharing options...
Guru Posted August 1, 2006 Share Posted August 1, 2006 £140 and a 3 year waranty! Too tempting...... Link to comment Share on other sites More sharing options...
