imi Posted July 16, 2006 Share Posted July 16, 2006 Hey all. Need some advice. Have a look at the attached pic, I would like to move the boost gauge to the slot where the clock sits and reinsert the airvent. Now I do have the air-vent, question is, are there any gobbins that sit BEHIND the dash that feed into the air-vent? if so, then does anyone have those.... Link to comment Share on other sites More sharing options...
wkdtime Posted July 16, 2006 Share Posted July 16, 2006 No pic? Link to comment Share on other sites More sharing options...
imi Posted July 16, 2006 Author Share Posted July 16, 2006 No pic? Link to comment Share on other sites More sharing options...
wkdtime Posted July 16, 2006 Share Posted July 16, 2006 Lol you just put that there now, making me look numpty are we now? Link to comment Share on other sites More sharing options...
wkdtime Posted July 16, 2006 Share Posted July 16, 2006 Are you going to cut around the Clock din so that it can house the 60mm gauge or are you going for a 52mm gauge? Link to comment Share on other sites More sharing options...
imi Posted July 16, 2006 Author Share Posted July 16, 2006 I think this is a 52 mm gauge....the way its fitted at the moment is and you wont believe this....is a LOT OF ELECTRIC TAPE to make it thicker. Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 16, 2006 Share Posted July 16, 2006 imi just looking at the pic it doesent look like a 52mm because if you look at the glass part of your gauge it seems to be bigger than the clock itself mate Link to comment Share on other sites More sharing options...
imi Posted July 16, 2006 Author Share Posted July 16, 2006 hmm...bugger.... so in that case, I'll probably remove the gauge as I have an AVC-R to keep an eye on boost. how do I go about replacing the air-vent....any gobbins in the back? Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 16, 2006 Share Posted July 16, 2006 hmm...bugger.... so in that case, I'll probably remove the gauge as I have an AVC-R to keep an eye on boost. how do I go about replacing the air-vent....any gobbins in the back? as far as i know, you can just put the vent back in, as theres a sort of pipe thing that carries the air to the vent which is there, probably not best explained by me, but if you remove the dash cover youll see what im talking about. and not sure of this but maybe its been blocked off as you removed the vent with tape or whatever. best thing to do is take it off and check behind, replacing the vent is easy Link to comment Share on other sites More sharing options...
wkdtime Posted July 16, 2006 Share Posted July 16, 2006 Imi i know its because of the hot sun and your missing the cold air from your Air con hitting the left side of your face. i say fight it, winter is round the corner, so leave it where it is. There is a little duct in the back which directs the air but thats about it i think. Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 16, 2006 Share Posted July 16, 2006 There is a little duct in the back which directs the air but thats about it i think. duct thats the word i was looking for lol. Link to comment Share on other sites More sharing options...
imi Posted July 16, 2006 Author Share Posted July 16, 2006 Imi i know its because of the hot sun and your missing the cold air from your Air con hitting the left side of your face. Yeah...my face is a tale of two halves...LOL Link to comment Share on other sites More sharing options...
DannoSupra Posted July 16, 2006 Share Posted July 16, 2006 the only thing that holds these vent on are 3 prongs, it just clips n place! Link to comment Share on other sites More sharing options...
