Slow Supra
ChrisB
Anyone have an idea what this could be, i put my foot down gradually was doing about 100, then carried on the boost gauge showed that the second turbo came in and it was noiseier like the 2nd turbo was in, but it didnt go any quicker, then all the sudden i got a blast of power from the second turbo, but far too high in the rev range for normal, any ideas what it was didnt do it again just that one time as far as i know, didnt really get another chance to test it any ideas what this could be
Cheers
Chris
Sometimes the sequential system can tie itself in a knot and #2 doesn't come online or does it late. Lifting off and booting again sorts it out. It's happened about 3 times in 2 years for me, may only affect non-stock cars.
-Ian
I had this once. The 2nd turbo started coming on line at around 4.5k rather than 4k. Then after a while not at all.
Turned out to be a completely split rubber hose above the turbo area. Im guessing it was able to hold boost for a bit while the split was very small, but lost it completely as it got bigger.
Just a thought and i could be very wrong but check your hoses anyway.
When i first bought my Supra i thought it was amazing...then i thought i got used to the power and it didn't seem as quick as it did, i recently have put a purple hose techniques kit on my car and replaced all the vac hoses and the cars back to normal, all i can think of was that i had a split hose and it was leaking boost a bit. Sounds like it may be that Chris.
Paul
Originally posted by ChrisB
hmm could be boost leak, but would the boost gauge still show the correct boost?
will have to investigate this :S
paul whats ttc:stupid:
TTC = True Twin Conversion
both turbos come ontogether at about 4000 rpm and is a much stronger kick. a bit laggy off mark
Originally posted by Paul Laing
Apparently the Yanks love TTC, they reckon theres no lag with a 6 speed manaul Paul
Hmmmm.... depends how much you are prepared to change gear.
You need to change your driving style for TTC, off boost there is no real power so you either go down the box or wait an age for the car to build boost.
Paul,
I have a conversion done by Matt H which is a swittch on the dash that allows you to switch between TTC and standard. It works well and allows you to have the best of both worlds whenever you want it. I remeber it being cheap as well around £30-£50 but Matt H will confirm I'm sure..
Cheers
Originally posted by Matt B
Paul,
Cheers
i want to try this. how much matt?
