Servicing Air Con....?
Martin
 Share
Guest banherc
The only problem with that is, the fuel consumption goes down even more when the AC is used all the time! :(
Very true, but just run the air con more often then, it will stop the compressor oil seal becoming to dry and therefore leaking gas, which in the long run could ruin the compressor (big bucks then). :sly:
fule consumptions rubbish anyway, so i doubt the aircon being on is going to make a noticeable difference. It doesn't have to be used akll the time, a good run every month should work I think, mine just sat around for 3 months so was no good
 Share
