Ray Posted January 18, 2004 Share Posted January 18, 2004 Hey guys, Any idea on where to get brake pads for my UK spec TT? Was thinking of going to mr T's, but if anyone has any better suggestions much appreciated. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted January 18, 2004 Share Posted January 18, 2004 I'm sure we had a traders section on this forum..... Also try a search, brake pads is a favourite topic, Chris Wilsons being a good start. Or as stated above, try Envy/Paul Whiffin or one of the other traders. They all got good stuff. Ben.. Link to comment Share on other sites More sharing options...
suprarob Posted January 18, 2004 Share Posted January 18, 2004 I,ve just bought from toyota £56.01 plus vat you will probably need new pins as well 89 pence each I think this is good value as the toyota pads are good and when at toyota allways ask for a discount usually 10% Link to comment Share on other sites More sharing options...
Gaz Walker Posted January 18, 2004 Share Posted January 18, 2004 We do the Porterfield Fast Road pads for £115.50 inc VAT. Link to comment Share on other sites More sharing options...
dude Posted January 18, 2004 Share Posted January 18, 2004 Chris Wilson's IMO the best you can buy , i use the fast road compound but he also does a race/trackday compound which is messier and noisier but even more powerfull , i took the advice of another member with a big power sup who does trackdays and steered away from the porterfields , i am so immpressed with CW's i wouldnt think about anything else , i also have Steel lines and have removed the squeal shims but if you do this ask Chris for some of his blue goo !!!! Dude:flame Dev Link to comment Share on other sites More sharing options...
Scooter Posted January 18, 2004 Share Posted January 18, 2004 i'd back up Dudes comments re Chris Wilson pads. I haven't changed the hoses or put in new fluid yet but the improvement is massive for J-spec brakes. I've got the Race spec ones and they squeal alot (under light braking mainly) and as has been said create alot of dust. This is not a problem for me running 16's but would be a big issue if i had £2K's worth of split rims, as you'd need to be constantly cleaning them. Not sure what the dust and squeal is like on the fast road spec pads? Having said all this i never found the need for uprated pads when i had my UK car, and if i own a supra in the future with UK spec brakes i'd stick with standard pads as for me the performance is great as standard and you get none of the potentially annoying side effects mentioned above. Link to comment Share on other sites More sharing options...
Geezabloke Posted January 18, 2004 Share Posted January 18, 2004 Bit of a side line, im running standard T pads on a UK and have noticed at light use a squeal of late?...any ideas on how to cure?....Copper grease? Link to comment Share on other sites More sharing options...
SkyJawa Posted January 19, 2004 Share Posted January 19, 2004 I'm luvin the Porterfield Fast Road Gaz supplied me in my new UK brake setup Link to comment Share on other sites More sharing options...
