JimC Posted June 15, 2006 Share Posted June 15, 2006 hey guys, something i have noticed with my new supe is hot exhaust temps! When im pushing it, it does go over 850 a lot. I wasn't sure if this was about right, or a little hot. How much difference will taking out the bottom CAT make? That is due pretty soon. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 15, 2006 Share Posted June 15, 2006 950+ is when you should start to become worried. 850 is not a problem. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 15, 2006 Share Posted June 15, 2006 Bottom CAT out will increase the boost, so it might start gettting a little hotter. Get some basic fuel mods if you are going to be pushing higher boost on stock jap stuff. Link to comment Share on other sites More sharing options...
Kopite Posted June 15, 2006 Share Posted June 15, 2006 Where's the EGT probe positioned? Link to comment Share on other sites More sharing options...
Alex Posted June 15, 2006 Share Posted June 15, 2006 Where is the probe fitted?? This is v.important when discussing the temps. If it's fitted in the manifold pre turbo then 850 is very safe. If it's post turbo then you're running high as you maybe seeing 1000degC before the turbo. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 15, 2006 Share Posted June 15, 2006 D'oh good point I missed. Link to comment Share on other sites More sharing options...
JimC Posted June 15, 2006 Author Share Posted June 15, 2006 its fitted in the maifold Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 15, 2006 Share Posted June 15, 2006 What boost are you running Jim? Link to comment Share on other sites More sharing options...
JimC Posted June 15, 2006 Author Share Posted June 15, 2006 1.1 max Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 15, 2006 Share Posted June 15, 2006 That EGT is fine, taking the 2nd cat out will reduce it a bit, even if the boost goes UP to 1.2 bar as a result of the reduced back pressure. 900 C is OK, 950 C is iffy on cast pistons, 1000 C is bye bye pistons time. Link to comment Share on other sites More sharing options...
JimC Posted June 16, 2006 Author Share Posted June 16, 2006 thanx guys, appreciate that. The decat will be happening soon...fingers crossed Link to comment Share on other sites More sharing options...
