C5 SUP Posted June 13, 2006 Share Posted June 13, 2006 Good morning, I have just purchased a TRD rad cap for my NA, but it does not fit at all. I have done a search and in one thread Nic says that TRD do two types of rad cap. Does anybody have any pics of both types of TRD caps as the supplier may have sent the wrong one... or I may have an aftermarket rad. Cheers, Chris. Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2006 Share Posted June 13, 2006 Good morning, I have just purchased a TRD rad cap for my NA, but it does not fit at all. I have done a search and in one thread Nic says that TRD do two types of rad cap. Does anybody have any pics of both types of TRD caps as the supplier may have sent the wrong one... or I may have an aftermarket rad. Cheers, Chris. Hi Chris 16401-SP030 is the correct part number for stock Supra radiator. Sounds like you have been sent the wrong one, unless you have a non stock radiator. cheers Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2006 Share Posted June 13, 2006 The same of the cap should be likes this: This is the wrong one: Link to comment Share on other sites More sharing options...
C5 SUP Posted June 13, 2006 Author Share Posted June 13, 2006 Thanks Nic, Will check this when I get home. Just woke the missus up to check. The part no. I have is 16401-SP002 so will have to get this sorted Thanks for your help. Link to comment Share on other sites More sharing options...
Ewen Posted June 13, 2006 Share Posted June 13, 2006 The same of the cap should be likes this:QUOTE] Hes even started talking Chinese:p Link to comment Share on other sites More sharing options...
gaz1 Posted June 13, 2006 Share Posted June 13, 2006 The same of the cap should be likes this:QUOTE] Hes even started talking Chinese:p mmmmm you mean japanese:p Link to comment Share on other sites More sharing options...
Ewen Posted June 13, 2006 Share Posted June 13, 2006 mmmmm you mean japanese:p Has Hong Kong been towed south then ? Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2006 Share Posted June 13, 2006 Has Hong Kong been towed south then ? You mean North Ewen Now all of you Link to comment Share on other sites More sharing options...
