SimonR Posted June 3, 2006 Share Posted June 3, 2006 Reading the specs of Tein SS and Tein Flex, I see that the Flex says "Full-length adjustment and height adjustment for separate setting of the height and spring preload..." but the SS doesn't. This implies that you can't play with combinations of height/ride separately on the SS. Can anyone confirm, please? While we are on the subject,does anyone have any views on why the Flex is nearly twice as expensive as the SS - ie are they worth the difference? Link to comment Share on other sites More sharing options...
supradibbs Posted June 3, 2006 Share Posted June 3, 2006 the super street is fully ride height adjustable and rebound adjustable Link to comment Share on other sites More sharing options...
baldy Posted June 4, 2006 Share Posted June 4, 2006 fitted super streets yesterday they are very nice transformed the car Link to comment Share on other sites More sharing options...
Need4Speed Posted June 5, 2006 Share Posted June 5, 2006 Preload doesn't affect the ride height. Don't forget to do the corner weights - they don't have to be perfect, just close. Link to comment Share on other sites More sharing options...
SimonR Posted June 5, 2006 Author Share Posted June 5, 2006 Sorry - cornerweights? Link to comment Share on other sites More sharing options...
Need4Speed Posted June 5, 2006 Share Posted June 5, 2006 The weight of the car is obviously in four components - but how much weight is on each of its four wheels? If you've got an adjustable system where you can adjust the ride height by screwing the spring platforms up and down, you need to get the left/right balance correct. You can achieve a certain ride height, but the balance of the car on the left or right sides may be out. To check this you need a corner weight gauge, or a similar means of checking how much weight is on your front left and front right wheels. To increase weight on the front left, for example, you screw up the rear right, to increasae the load on the front left. If it's a way out left/right, among other things you'll find your braking is greater on one side compared to the other. Link to comment Share on other sites More sharing options...
n00b Posted July 18, 2006 Share Posted July 18, 2006 The weight of the car is obviously in four components - but how much weight is on each of its four wheels? If you've got an adjustable system where you can adjust the ride height by screwing the spring platforms up and down, you need to get the left/right balance correct. You can achieve a certain ride height, but the balance of the car on the left or right sides may be out. To check this you need a corner weight gauge, or a similar means of checking how much weight is on your front left and front right wheels. To increase weight on the front left, for example, you screw up the rear right, to increasae the load on the front left. If it's a way out left/right, among other things you'll find your braking is greater on one side compared to the other. silly questions but where would you go to get this measured... or is it really specialist... lol i take it my bathroon scales are out of the question:eyebrows: thanks n00b Link to comment Share on other sites More sharing options...
Need4Speed Posted July 18, 2006 Share Posted July 18, 2006 Anybody who builds or prepares racing saloons or rally cars may be able to help. I've got a corner-weight guage but it's only for single seaters - 200kg per corner max. Not much help for a Supra. Probably some Rally people in your area. Like I say, it's not critical, but it will affect your cornering and braking if it's way out. PS bathroom scales are fiine if they're calibrated to half a tonne and you've got two of them! Link to comment Share on other sites More sharing options...
