foodfreak Posted December 27, 2003 Share Posted December 27, 2003 Does anyone know how much of a drain using the intellistart puts on the battery, mine seems to be running out of charge quickly. I think this might be to do with me using the intellistart too much thanks, John Link to comment Share on other sites More sharing options...
Gaz Walker Posted December 27, 2003 Share Posted December 27, 2003 I wouldn't have thought any more than you starting in and stopping it the same way? Might just be due for a new battery. Gaz. Link to comment Share on other sites More sharing options...
foodfreak Posted December 27, 2003 Author Share Posted December 27, 2003 Hi Gaz, thanks for the reply, i just wasn't sure. Matt did say that using the intellistart could drain the battery, i will check with him later. Regards, john Link to comment Share on other sites More sharing options...
Gaz Walker Posted December 27, 2003 Share Posted December 27, 2003 I had it on my old car (C600 + intellistart) and used it 2/3 times a day and had no problems for nearly a year... Gaz. Link to comment Share on other sites More sharing options...
foodfreak Posted December 27, 2003 Author Share Posted December 27, 2003 It could well be the battery then, even tho it's only 2 years old John Link to comment Share on other sites More sharing options...
Nick_TC Posted December 27, 2003 Share Posted December 27, 2003 Might be worth checking the alternator, should be putting out 13.5-14.5 volts when under load (lights on, heater blowers on). Cant see it being the intellistart, unless your starting it and then stopping it without the car being driven. Link to comment Share on other sites More sharing options...
MONKEYmark Posted December 27, 2003 Share Posted December 27, 2003 i have had mine on car for 3+ years and has been ok. but i have had a new battery on. also had a new battery on astra too. i always used remote start. the battery in the alarm fob tend to go pretty quick but they only £1 each and carry a few spares along with a few rear bulbs that cost 50p each i have been having a bit of trouble with astra. turns out its fanbelt slipping and brand new battery was not holding charge. got new fanbelt £3.30 to fit. always spend spend spend with cars Link to comment Share on other sites More sharing options...
AJI Posted December 27, 2003 Share Posted December 27, 2003 What is 'intellistart' ? Is this something every Supra owner should know? Link to comment Share on other sites More sharing options...
foodfreak Posted December 27, 2003 Author Share Posted December 27, 2003 voltage when running o.k 13.5- 14.2 must be the battery:( Link to comment Share on other sites More sharing options...
jagman Posted December 27, 2003 Share Posted December 27, 2003 every engine start takes 6-10 miles to replenish the battery,so short trips slowly reduce battery capacity,when temp drops battery capacity also drops, plus cold engine oil(thicker) puts more load on starter - hence winter battery probs-best slow charge 1-2 amperes for 48 hrs at beginning of winter.its hard to find the old fashioned chargers with low current,usually the made in china 5/7/10 amp halfrauds type which have very poor regulation on them and can buckle the lead plates in battery or cause deposits in battery case. ive got a couple of old chargers that i use,got them at an autojumble for £3 each should last another 30 years:) Link to comment Share on other sites More sharing options...
foodfreak Posted December 27, 2003 Author Share Posted December 27, 2003 that could well be my problem.... too many short stop, start trips with very few mile in between. John Link to comment Share on other sites More sharing options...
Gaz Walker Posted December 27, 2003 Share Posted December 27, 2003 Originally posted by foodfreak that could well be my problem.... too many short stop, start trips with very few mile in between. John Considered a run-a-bout John, that wont do the Supe a lot of good...? Gaz. Link to comment Share on other sites More sharing options...
foodfreak Posted December 27, 2003 Author Share Posted December 27, 2003 had one Gaz, had to get rid....... no bloody space for a second car:( that's living in london for you. but I ALLWAYS let it warm up/cool down properly.... it's just recently I had to do a lot of Client Venue visits with small distances between That's Life Link to comment Share on other sites More sharing options...
