Batgirl Posted December 11, 2003 Share Posted December 11, 2003 Could anyone help on how to get the tensioner arm back because the arm has gone out as far as it can go. I'm having problems trying to get it back and would appreciate any help anyone could give me cos I've not yet started to pull it apart. I don't want to risk breaking anything. I am sure I have the correct layout but would like to double check. Link to comment Share on other sites More sharing options...
Steve W Posted December 11, 2003 Share Posted December 11, 2003 do you mean the ALTERNATOR belt tensioner B'G' ??? Link to comment Share on other sites More sharing options...
Batgirl Posted December 11, 2003 Author Share Posted December 11, 2003 yes that's the one Link to comment Share on other sites More sharing options...
Steve W Posted December 11, 2003 Share Posted December 11, 2003 It 'just' pushes back...... but BOY, does it take some PUSHING ! ! It's just an internal spring of some sort (?) and happily pushes back to allow the belt on. BUT, you have to 'crowbar' it backwards (obviously without bending/ruining, so on the 'solid' bit of the arm) FatS. Link to comment Share on other sites More sharing options...
Steve W Posted December 11, 2003 Share Posted December 11, 2003 I think the tensioner DAMPENER (the Gas ROD thingie) causes most of the resistance when you're trying to force it back. BUT, you can't really take THAT off - too much hassle to put THAT back on then ?!? (best ONE person 'prises' arm away, and OTHER puts the belt round the pulley ?) Link to comment Share on other sites More sharing options...
Batgirl Posted December 11, 2003 Author Share Posted December 11, 2003 thanks - much obliged. Link to comment Share on other sites More sharing options...
richardharmon Posted December 12, 2003 Share Posted December 12, 2003 I just put a socket set on the nut that holds the pully part and move it the same direction you would to tighten the nut, works a treat for me. I'm not saying it's easy to move by any means, but I can get the belt on without help if I use this method. Link to comment Share on other sites More sharing options...
Terminator Posted December 12, 2003 Share Posted December 12, 2003 Try this. http://www.mkiv.com/manual/manualtt/drive_belt_inspection/index.html Link to comment Share on other sites More sharing options...
richardharmon Posted December 12, 2003 Share Posted December 12, 2003 Yes, just like that! Link to comment Share on other sites More sharing options...
Batgirl Posted December 12, 2003 Author Share Posted December 12, 2003 Thank you soooooooooo much for that!! I should have all I need now (hopefully!!!) Getting the new rad tomorrow. Crank shaft pully sorted so tomorrow is the big day!!! Will keep you posted. Out of interest - I have ordered a manual from JZNZ which will hopefully arrive soon but is the whole manual on a website relating to Jap spec Supe auto TT (L reg 93)? Like I said all my docs are in Japanese so until I get a grip of the lingo I'm a bit stuck - mind you with all you guys it seems I shouldn't need a manual at all Link to comment Share on other sites More sharing options...
Steve W Posted December 12, 2003 Share Posted December 12, 2003 " BATGIRL, BATGIRL..... so good she said it THRICE ! ! " Link to comment Share on other sites More sharing options...
Batgirl Posted December 12, 2003 Author Share Posted December 12, 2003 oops sorry it's Friday - I was just so excited about being able to drive my beautiful Supe again! Link to comment Share on other sites More sharing options...
