wkdtime Posted May 12, 2006 Share Posted May 12, 2006 after considering the pros and cons and what id be wanting from my car and the budget i have to spend i have decided to go for the BL T67 DBB stage 2 kit hopefully at the end of the year. Below is a Dyno run sheet from one of the boys over the pond and im pretty sure Ian C was making 600whp with 1.4 bar boost (stand to be corrected). The car made 493whp/444tq @ 18psi 554whp/489tq @ 23psi 634whp/562tq @ 28psi Mods include Boost Logic T67-DBB .68AR P-Trim 4" DP/MP HKS 264 cams HKS VPC/SAFC2/G-Force RPS Carbon/Carbon Boost Logic Fuel System 84lb injectors "Also i made another run after the 634whp and richened it up some and still made 618whp with a very safe 11.4AFR across the board from 4.5k-7.5k" Quote Link to comment Share on other sites More sharing options...
Alex Posted May 12, 2006 Share Posted May 12, 2006 Ian's got more info coming... I've seen it and it's interesting reading. That particular car isn't making good power...Ian made 580RWHP at 20psi on a 67p trim. EDIT - actually that dyno is horrible!!! That's not set up well at all!! Quote Link to comment Share on other sites More sharing options...
Digsy Posted May 12, 2006 Share Posted May 12, 2006 I thought Ian's figures were estimates of flywheel power, not rear wheel? Quote Link to comment Share on other sites More sharing options...
wkdtime Posted May 12, 2006 Author Share Posted May 12, 2006 Ian C's are RWHP figures, check out his garage. Quote Link to comment Share on other sites More sharing options...
Alex Posted May 12, 2006 Share Posted May 12, 2006 I thought Ian's figures were estimates of flywheel power, not rear wheel? 620+ estimated at the Fly. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted May 12, 2006 Author Share Posted May 12, 2006 EDIT - actually that dyno is horrible!!! That's not set up well at all!! I see what you mean, quite erratic. Quote Link to comment Share on other sites More sharing options...
Alex Posted May 12, 2006 Share Posted May 12, 2006 I see what you mean, quite erratic. Yeah and at 28psi he's looking at melted pistons/valves etc...nearly 13:1's!!! Quote Link to comment Share on other sites More sharing options...
wkdtime Posted May 12, 2006 Author Share Posted May 12, 2006 Ian c made 580 RWHP and just like Alex stated around 620 ish at the fly. see below Ian C's dyno run sheet. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted May 12, 2006 Author Share Posted May 12, 2006 Yeah and at 28psi he's looking at melted pistons/valves etc...nearly 13:1's!!! Is that because hes running to high boost? or the fuelling isnt up to match? or both? Quote Link to comment Share on other sites More sharing options...
Alex Posted May 12, 2006 Share Posted May 12, 2006 Is that because hes running to high boost? or the fuelling isnt up to match? or both? I'm not sure...his equipment is pretty low spec for controlling the fueling - it looks like he's made no attempt to add extra fuel for the higher boost levels...ie he just upped the boost. Quote Link to comment Share on other sites More sharing options...
LeeT Posted May 12, 2006 Share Posted May 12, 2006 good choice of turbo kit. you cant really go wrong with the boostlogic stuff Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 12, 2006 Share Posted May 12, 2006 How are you going to control the fuelling/timing mate, sorry just saw it's a VPC. Those injectors are approx 880cc. You need the VPC chip to be as close as possible. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted May 12, 2006 Author Share Posted May 12, 2006 How are you going to control the fuelling/timing mate, sorry just saw it's a VPC. Those injectors are approx 880cc. You need the VPC chip to be as close as possible. Terry when i plant to go single with the above stated kit, for fuelling i was looking to drop in 720cc injectors and depending on budget will probably go for the emanage, if i can stretch it then id try for stand alone ECU. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 12, 2006 Share Posted May 12, 2006 sorry mate misread the first post. That sounds fine but drop in 800's maybe better and are at the limit of the EMU control capabilties Quote Link to comment Share on other sites More sharing options...
