Keeping a speedon in KM/H but with 300km/h face
JohnK
I have a friend who needs to keep his speedo in KM/H but also wants to remove the stock J-spec top speed limiter and have a 300km/h dial.
As standard 180km/h is around the 3 o'clock position so just replacing the dial face will mean the readings are way out.
Any idaes please.
I know the Thor speed converter is variable, but to what extent I'm not sure.
You could possibly use one convertor to feed the speedo and another true mph speed for the odo and rest of the system.
Just buy a TRD gauge.
use a thor speed converter delimiter
That should delimit the car and give you your readout in mph
so 180 km/h on the stock clock becomes 180 mph
now just replace your dials
done
john
He needs the speedo in KM/H not MPH.
Pete: The Thor box is only +/- 10%
Any more ideas please?
It still applies
Just replace the dials with a km/h one
If the dial is properly calibrated, which a reputable one will be.
Where the stock would read 180 mph it will now read roughly 290 km/h
  • 3 months later...
