Daston Posted May 4, 2006 Share Posted May 4, 2006 Hi guys Just finished spraying my dash and went to put it all back together however I cant get the rear fog switch working I havnt a clue what wire goes where I know I should have numbered the wires but hindsight is a wonderful thing. Pics in this order The switch has 3 connectors labled 3 2 1 (from the pic) I have a cable that runs down buy the gear stick so I guess that is from the fog light. I have 2 that come off the clock wires black and brown The last one runs all the way under the speedo and dissapears up past the drivers side air vent havent a clue what its for. please please help Quote Link to comment Share on other sites More sharing options...
Daston Posted May 4, 2006 Author Share Posted May 4, 2006 anyone?? Quote Link to comment Share on other sites More sharing options...
JODY T Posted May 4, 2006 Share Posted May 4, 2006 I did this, tried every combination. but nothing.. Checked the fuse and ide blown it, i replaced and it was fine.. Quote Link to comment Share on other sites More sharing options...
Supradan Posted May 4, 2006 Share Posted May 4, 2006 depending on how its wired you should have a feed to switch then a wire going back to fog and a ground to switch to make the light on switch work. On mine pin 1 is for feed,pin 2 is to fog and pin 3 is to ground but dont take that as gospel as yours could be diff,you need to test switch to find out. Quote Link to comment Share on other sites More sharing options...
