Patrick_Devlin Posted December 5, 2003 Share Posted December 5, 2003 Done a few searches on fuel computers but nothing really has answered my question! As the car is running lean at high boost it has been recommended that a Fuel Computer is the order of the day. The Apexi AFCII has been recommended but I'm not all that hung up on the display... bit garish. 1. Can the Apexi unit be stuffed into the Din section beneath the single radio slot in the dash as I dont fancy it stuck on the side somewhere? 2. Is this unit the only decent fuel computer around? I've read a bit about the GReddy E-Manage system, but this seems a bit overkill to me? 3. What about the HKS one, is that any good? Comments please... Thanks Link to comment Share on other sites More sharing options...
Sharpie Posted December 5, 2003 Share Posted December 5, 2003 I know nothing about these but, just what I have found with a quick look. Super AFR A/F Knock Amp with a new style display And select A/F Knock Amp from the drop down box for more info Link to comment Share on other sites More sharing options...
Darren Posted December 7, 2003 Share Posted December 7, 2003 Mines going in the glove box...HTH Cant help with the other q's. Darren Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 7, 2003 Share Posted December 7, 2003 Have you already got a high pressure pump and regulator? Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted December 8, 2003 Author Share Posted December 8, 2003 Thanks chaps, Matt, I've got standard Jap fuel pump and injectors at the moment, no regulator. Link to comment Share on other sites More sharing options...
Dragonball Posted December 8, 2003 Share Posted December 8, 2003 May I suggest an immediate change to the Walbro and FSE which will help get more fuel in when necessary The AFC will really only lean out and not increase your fuelling past the levels at which the std injectors can manage Same cost roughly for pump and FSE as for Apexi S-AFC Link to comment Share on other sites More sharing options...
