Idle speed
FaithStalker
Hey All,
When i first got my supra a few months ago,
the idle was very high (and went up and down when the a/c was on)
but now, its very low and seems a little rough.
I have a j-spec, and just use straight unleaded (cant afford other stuff)
could it be the cold that has caused the lower idle speed?
or could it be the ECU has mapped to the lower grade fuel
i am using?
It should idle at about 6-800rpm...its low because of the amount of torque it produces even at that speed.
Mine varies on a daily basis...the only thing I have tried to settle it down is to make sure I use the same type and make of fuel I use...for me its Shell Optimax...but if optimax didn't exist I'd use say Esso but I'd stick to Esso.
If your still worried some thing is wrong...try pulling both fuses on the ECU for 30 mins and then go out for a long drive with varying circumstances...ie go through a town and then out on fast duelies etc.
Have you checked to make sure you have a standard J-spec ECU?
Guest Martin F
Hmmm could be they are getting on a bit.
I wouldn't guarantee that JIC changed them, so it's probably worth swapping them out.
Speak to shop about new plugs, i think NGK are the preferred make.
As for how to do it, take a look at :-
http://www.mkiv.com/manual/manualtt/general_maintenance/mo3.jpg
Just watch for the two oil pipes underneath the spark plug cover, apparently they have a tendency to go hard and brittle over time.
Yes  as Martin says watch those two breather pipes. It is a good idea to buy some and  keepthem  for plug changes, I have the part numbers somewhere if you want them.
My car was "serviced" buy  JIC. I don’t  know what oil they used  but I changed it after 500 miles as it was too dark.  When the plugs where changed about 3000 miles later they were in a state, no way  had they been changed either.
I am sure  MKIV.com has plug change instructions.
I wonder if one of your coil pack does  not like the cold and damp, does it get better after a warm up?
60,000 miles is recommended max. interval for the *platinum-tipped* plugs.
The platinum ones were standard on UK-specs (:biggrin:) but i don't think they were used in the J-specs (though i may be worng there).
Non-platinum tipped plugs have a much shorter service life.  Maybe 10-20,000 miles or so.
I beleive the plug code for NGK is something like NGK BCPR7-ES.   (that' for a grade 7 plug which is advisable if you're running above stock boost).
"stock" plug grade is grade 6.    That would be : NGK BCPR6-ES or similar.
The platinum tips were on both UKand J-specs, but should  still be changed sooner, as with the cambelt BTW.
My car was not serviced by the JIC, andI think they only do it if the car can't go without it, so if you have jusy brought a car from the (or any other dealer) get it serviced so you *know* it has had everything done for your own peace of mind.
...plus...
I know that your supposed to get cloudy-smoke on startup in this
cold weather,
but,
after the engine has warmed up and i've driven around for about
20 mins, when i stop, theres a crap loads of whiteish smoke.
when i get out and look at the exhaust, there is a constant kinda
puffing of smoke, but when i press the accelerator again, theres
a whole load of smoke again,
i know smoke is bad, the colour is whiteish, but could this also
be a problem?
theres a constant chugging sound when the engine is hot or cold
and when you give it a but of wellie it becomes really noticeable !
ahhhhhhhhhhhhhhhhhhh back to JIC it goes (4th time !)
White smoke from the exhaust could mean there is water leaking into a cylinder(s) or into the exhaust manifold. Chugging sound could be a cylinder missing which would explain the erratic idle.
This thread is starting to sound expensive. :(
Yours,
J
If it is water entering the cylinder then it is almost certainly will be engine cooling water. In which case, the water level will deplete over time.
There could be other clues such as bubbles in the coolant and gurgling noises after the engine is switched off when hot. Sometimes there can be water contamination of the oil, denoted by a sludgy, frothy mix permeating the sump area and shown on the dipstick.
If it *is* water contamintion then it'll be expensive. So better check those warranty documents carefully and watch what you say when you take it back. If you have changed anything on the engine from stock since you bought it, then I'd suggest you refit the stock stuff PDQ.
Yours,
J
Yours,
J
For coolant level check you expansion tank.
You may notice a cream coloured film on the oil filler cap.
When you open the bonnet the expansion tank is just in front of the radiator, about where your right knee is.  You should be able to see in from the left side (looking at the front of the car) and there will be a min and max levels.  Should be inbetween those.  Make sure you do this when it's cold.
Take off the radiator cap and the 'water' should be up to the top.
If it's not then top up the radiator and then do the expansion tank to the max level.  I'd just use water at this stage, but you may get better advice, as if you have a problem you will probably be getting it drained soon anyway.
Check it every day.
How does your water temperature gauge behave?  Especially after a goot WOT run?
Guest Martin F
Yours,
J
More expensive than a set of spark plugs anyway.............. :(
Quote: from ajefford on 11:01 am on Nov. 15, 2001[br]Its totally stock, nothing has changed
except perhaps my optimitsic opinion of Toyota's reliability !
Phil - expansion tank? where is that?
Ash  - bubbles in the coolant? is where you check
the water level near the radiator?
If I were you I wouldn't start messing with it as you could invalidate your warranty and, from what you have said, that is the very last thing you want to be risking right now.
I would also read the terms and conditions carefully. Especially as regards reporting faults within a certain number of days and conditions regarding servicing. Just to make absolutely sure they cannot wriggle out of anything.
As I say, if it IS water leaking into one or more cylinders it WILL be an expensive fix.
Yours,
J
Lunchtime today,
started it up - fine, took it for a run, still sounded a bit chuggy,
picked up ok, stopped - left it to idle, was idling around 400-600,
no smoke, temp guage showed 1/2 (which is where it usually is!)
listening to the engine, constatant tapping noise from the
metal box to the right of the "main" engine - is that the fuel-injectors?
its where the accelerator cable goes into.
listening towards the front of the exhaust, next to drivers door,
sounds like water dripping onto a hot metal plate - like a
spitting - could just have been the metal "creaking" as it cools,
but it didnt sound like it -
checked my radiator water, while engine was running,
no bubbles at all - moved up and down a lot though, it was well FULL, looked slighty browny/green colour, antifreeze?, checked the expansion tank - same kinda colour, no movement in thier at all,
checked the oil, looked "thin" but ok!
revved it a lot, no smoke at all this time - slight kinda steamy smoke,
but very thin, and didnt increase with revving.
strange !
think i'll give it another week and keep an eye on things....
but guys - hey - thanks for the advice - more than toyota did for
me !
If i can ever repay the favour with what little knowledge i have,
then i'll try !
What do you mean by "moved up and down a lot" ?
Yours,
J
