What boost will i be able to run with this setup?
Pig
Auto box can handle about 500?? Thats about the limit of a T61 anyway. Must be honest though, would be pretty gutted if it went pop! Run the car with out the TC fuse, would have thought that may help end the auto box's life early!
Good luck with it. I hope things are a little simpler than mine has turned out to be!
Bring on the next bovingdon, student drag race coming on.
(Even though i left uni, i could pretend to be a student)
Just wondering what boost i will be able to run with this setup!
UK Spec
T61
550cc injectors
Greddy 3 row front mount IC
Without winding the fuel pressure up, 1bar tops from my experience. You might run more but you'd be north of 90% duty cycle.
This is from having seen the duty cycle on 530cc injectors on a T61 at 0.8bar boost, with I think 38psi static pressure - not sure what people are basing their 1.4bar estimates on ;)
-Ian
