Remote Control Key Fob
Guest Jonno2020
Guest Jonno2020
I have a standard Toyota (Import) key fob with the remote control for central locking but it doesn't work. Does anyone know where I could either send it away to be repaired or replaced??
Frustrating when it's there but doesn't work!!:blink:
Guest Jonno2020
I have but not too sure which type! Asked at a Toyota dealer and the bloke stated that he had never seen a Supra with remote central locking before!!
I think the 'gubbins' inside it is knackered.
Most imports will have been fitted with an aftermarket CAT 1 immobiliser, so the standard fob will not work anymore. If you have just imported this car, you will probably have to fit a CAT1 to insure it, so the standard fob isn't worth bothering about :)
