Guest Jonno2020 Posted November 6, 2003 Share Posted November 6, 2003 I have a standard Toyota (Import) key fob with the remote control for central locking but it doesn't work. Does anyone know where I could either send it away to be repaired or replaced?? Frustrating when it's there but doesn't work!! Link to comment Share on other sites More sharing options...
far Posted November 6, 2003 Share Posted November 6, 2003 Might be one you have already tried but have you put fresh batteries in there ? Link to comment Share on other sites More sharing options...
Guest Jonno2020 Posted November 6, 2003 Share Posted November 6, 2003 I have but not too sure which type! Asked at a Toyota dealer and the bloke stated that he had never seen a Supra with remote central locking before!! I think the 'gubbins' inside it is knackered. Link to comment Share on other sites More sharing options...
JohnK Posted November 6, 2003 Share Posted November 6, 2003 More likely that the bloke from Toyota hasnt seen a Supra before Link to comment Share on other sites More sharing options...
peter richards Posted November 7, 2003 Share Posted November 7, 2003 hi jonno , welcome . there is a very nice man called matt harwood he should be able to assist you .cheers peter Link to comment Share on other sites More sharing options...
Bobbeh Posted November 7, 2003 Share Posted November 7, 2003 The same age Rav 4's use the same fob. Its a standard toyota issue.. I've never heard so much crap in my life. Its only a damn battery! Link to comment Share on other sites More sharing options...
Gordon F Posted November 7, 2003 Share Posted November 7, 2003 Originally posted by Jonno2020 I have a standard Toyota (Import) key fob with the remote control for central locking but it doesn't work. Does anyone know where I could either send it away to be repaired or replaced?? Frustrating when it's there but doesn't work!! Most imports will have been fitted with an aftermarket CAT 1 immobiliser, so the standard fob will not work anymore. If you have just imported this car, you will probably have to fit a CAT1 to insure it, so the standard fob isn't worth bothering about Link to comment Share on other sites More sharing options...
