cookci Posted March 22, 2006 Share Posted March 22, 2006 does anyone elses auto nasp have a problem where it just runs out of power at 5K revs in 3rd with manu enabled? When i switch off manu it continues to pull again? is that something todo with the speedo conversion? is it legal for me to run the speedo in the standard configuration (in KPH)? Link to comment Share on other sites More sharing options...
Mike M Posted March 22, 2006 Share Posted March 22, 2006 yeah noticed mine doing that but with the O/D, foot to the floor in third and click the O/D on and it suddenly pulls harder. I've been ignoring it, i don't understand why it should make any odds. I bet it's the same on yours since the Manu button disables the O/D. Link to comment Share on other sites More sharing options...
cookci Posted March 22, 2006 Author Share Posted March 22, 2006 mine does it when O/D is off too and when u switch it woompf loads of extra power... weird has your speedo been converted? its hard to beleive our cars left the factory like this... this problem also makes me wonder if there are any other glitches in the power delivery Link to comment Share on other sites More sharing options...
carl0s Posted March 22, 2006 Share Posted March 22, 2006 does anyone elses auto nasp have a problem where it just runs out of power at 5K revs in 3rd with manu enabled? When i switch off manu it continues to pull again? is that something todo with the speedo conversion? is it legal for me to run the speedo in the standard configuration (in KPH)? What does nasp mean dude? I know it means na but what's the sp? I noticed you saying it yesterday. Link to comment Share on other sites More sharing options...
cookci Posted March 22, 2006 Author Share Posted March 22, 2006 same mate NASP = Naturally Aspirated Engine Link to comment Share on other sites More sharing options...
Mike M Posted March 22, 2006 Share Posted March 22, 2006 Yeah speedo and odo converted by vineplace, dunno what kind has been used tho. Its a strange one. The fault that is. Link to comment Share on other sites More sharing options...
cookci Posted June 29, 2006 Author Share Posted June 29, 2006 bump. really wish i knew where to start to try fixing it? Link to comment Share on other sites More sharing options...
Mike M Posted June 29, 2006 Share Posted June 29, 2006 I'm just guessing really but if the Autobox ECU takes a speed signal then maybe it's getting the wrong signal now it's been converted to mph like what happens when the power steering is too light. I'm probably totally wrong. Mike Link to comment Share on other sites More sharing options...
garethr Posted June 29, 2006 Share Posted June 29, 2006 MPH speedo is required by the Construction & Use Regs, but it's not checked in the MOT, so ........ Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 29, 2006 Share Posted June 29, 2006 oddly, my TT does this too - I thought it was normal! Link to comment Share on other sites More sharing options...
carl0s Posted June 30, 2006 Share Posted June 30, 2006 are you entirely sure that you're not just used to feeling the pull of second gear? Third gear @5,000rpm is somewhere around 110mph I think. Link to comment Share on other sites More sharing options...
Lucifer Posted June 30, 2006 Share Posted June 30, 2006 Its actual Torque converter slip without the manu button on you are experienceing when turnign it off half way through the rev range. Normal. Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 30, 2006 Share Posted June 30, 2006 Martin, can you expand on this at all please? Link to comment Share on other sites More sharing options...
Mike M Posted June 30, 2006 Share Posted June 30, 2006 Its actual Torque converter slip without the manu button on you are experienceing when turnign it off half way through the rev range. Normal. If i've read that right then your saying the Torque converter is slipping when the o/d or man button is turned off allowing the revs to shoot up about 1000rpm. It makes sense but i'm sure my one pulled harder after the revs shot up.(Ah wait, the revs shoot higher and into the engines power band and the car feels quicker than before). What causes it to slip? Link to comment Share on other sites More sharing options...
cookci Posted June 30, 2006 Author Share Posted June 30, 2006 it actually completely stops accelerating all together at 5k in manu mode. I can let off the throttle entirely and back on and still stopped dead... switch of manu mode and it starts pulling again. Link to comment Share on other sites More sharing options...
cookci Posted June 30, 2006 Author Share Posted June 30, 2006 MPH speedo is required by the Construction & Use Regs, but it's not checked in the MOT, so ........ might be an option to test it thanks Link to comment Share on other sites More sharing options...
carl0s Posted June 30, 2006 Share Posted June 30, 2006 it actually completely stops accelerating all together at 5k in manu mode. I can let off the throttle entirely and back on and still stopped dead... switch of manu mode and it starts pulling again. I was thinking about this thread on my long drive back from Harrogate just now. I was assuming you meant what you just said - loss of power after 5k, but then I though 'what if he actually does mean lag - then what Martin says would make good sense'. Anyhoo, you mean loss of power at 5krpm with MANU on, and that's what I just tested out in my car on the way back. My car kept pulling all the way to 6,000 when I lifted off 'cause there was a copper on the other side of the motorway. Was about 120mph on my over-enthusiastic clock. Something's wrong somewhere matey. My car was pulling hard all the way. Link to comment Share on other sites More sharing options...
Lucifer Posted June 30, 2006 Share Posted June 30, 2006 Fuel Filter Air filter Link to comment Share on other sites More sharing options...
carl0s Posted June 30, 2006 Share Posted June 30, 2006 Fuel Filter Air filter I can see the logic there, but you're forgetting that it's fine with MANU turned off.. Link to comment Share on other sites More sharing options...
Lucifer Posted June 30, 2006 Share Posted June 30, 2006 Oh I see. IN that case I dont know and am going to bed! Link to comment Share on other sites More sharing options...
cookci Posted July 11, 2006 Author Share Posted July 11, 2006 lol Link to comment Share on other sites More sharing options...
