Chase Posted March 20, 2006 Share Posted March 20, 2006 Just replaced a squeeking drive belt, and noticed the crank pulley is free to slide backwards and forwards! Now, I'm assuming it's not supposed to do this. Is it a big job to replace? and does anyone know how much these are from Toyota? Cheers Link to comment Share on other sites More sharing options...
D8MOA Posted March 20, 2006 Share Posted March 20, 2006 does it have the bolt in it still? Link to comment Share on other sites More sharing options...
D8MOA Posted March 20, 2006 Share Posted March 20, 2006 sorry had to ask lol Link to comment Share on other sites More sharing options...
Chase Posted March 20, 2006 Author Share Posted March 20, 2006 It does yes. The centre is attached firmly, but the outer section is sliding freely along it. Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 20, 2006 Share Posted March 20, 2006 The stock are 2 piece and can seperate. I have a 2nd hand one here cheap if you want it. Link to comment Share on other sites More sharing options...
Chase Posted March 20, 2006 Author Share Posted March 20, 2006 That's great Terry, how much do you want for it? Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 20, 2006 Share Posted March 20, 2006 PM me mate, and we'll sort it from there. Link to comment Share on other sites More sharing options...
carl0s Posted March 20, 2006 Share Posted March 20, 2006 and of course, don't drive the car at all until it's fixed. Certainly don't put your head in the engine bay with the motor running Link to comment Share on other sites More sharing options...
Chase Posted March 20, 2006 Author Share Posted March 20, 2006 But I've been driving it around like this for god knows how long. If you look down the front of the engine while it revs, you can see the outer part moving forwards about 7-8mm Link to comment Share on other sites More sharing options...
LeeT Posted March 20, 2006 Share Posted March 20, 2006 But I've been driving it around like this for god knows how long. If you look down the front of the engine while it revs, you can see the outer part moving forwards about 7-8mm if that pulley completely lets go you'll end up with a bloody great hole in your bonnet:D Link to comment Share on other sites More sharing options...
Chase Posted March 20, 2006 Author Share Posted March 20, 2006 Better tell the missus she'll be Astra-less for a bit then.. Link to comment Share on other sites More sharing options...
LeeT Posted March 20, 2006 Share Posted March 20, 2006 Better tell the missus she'll be Astra-less for a bit then.. it would seriously be in your best interest Link to comment Share on other sites More sharing options...
Chase Posted March 20, 2006 Author Share Posted March 20, 2006 Better safe than sorry. Cheers guys. Link to comment Share on other sites More sharing options...
chilli Posted March 20, 2006 Share Posted March 20, 2006 Is this something worth checking periodically then? Can you see it just run running the engine and looking down at it, or with the engine off, feeling for play...? Link to comment Share on other sites More sharing options...
Jspec Germany Posted March 21, 2006 Share Posted March 21, 2006 Sh*t, now u guys have me worried. I have a squeeky noise coming from the belt area, but I think it's actually the tensioner pully. Link to comment Share on other sites More sharing options...
Soop Dogg Posted March 21, 2006 Share Posted March 21, 2006 Someone posted a thread about this about a year ago with pics. When some other members here went to check theirs, I seem to remember at least a couple of people who found that the rubber ring which is between the inner and outer part had disintegrated and was in this condition. Worth a regular check, this. Link to comment Share on other sites More sharing options...
Soop Dogg Posted March 21, 2006 Share Posted March 21, 2006 Here you go http://www.mkivsupra.net/vbb/showthread.php?t=41040&highlight=bottom+pulley Link to comment Share on other sites More sharing options...
Jiversteve Posted March 21, 2006 Share Posted March 21, 2006 Just came accross this. Bling eBay item Pulleys for Toyota Supra alternator & crank underdrive Simple to install ADD 15 BHP!! Made in Uk ## Item number: 8047491610 Had same problem on a Celica years ago, Could not figure the squeek at first but finally sussed it when it fell off. Now that was fun getting at it with a transverse engine. Had to go in through the wheel atch etc etc. Link to comment Share on other sites More sharing options...
Digsy Posted March 21, 2006 Share Posted March 21, 2006 Just came accross this. Bling eBay item Pulleys for Toyota Supra alternator & crank underdrive Simple to install ADD 15 BHP!! Made in Uk ## Item number: 8047491610 Don't even go there. Aftermarket front crank pulleys are a bad idea. Link to comment Share on other sites More sharing options...
JohnK Posted March 21, 2006 Share Posted March 21, 2006 This is also often caused by people using heat to undo the crank bolt when changing the cam belt. Link to comment Share on other sites More sharing options...
