Have i got a problem or is this normal for a standard TT Supra!?
osso
For those of you who didn't know, I picked up my new supra on Friday its a 1998 RZ-S vvti with 6sp manual in quicksilver! I have already met Matt from Sextons and I think Bobbeh? with the Black GZ Supra and TRD spoiler who was having a EGT sensor fitted..
I had the opportunity to get to know my Supra driving over 600 miles this weekend, and I did notice a problem with the boost.. when I was driving the supra hard in mainly first and up to 4th gear the boost gauge would max out then cut down to zero when the rev's went over 5k rpm.. which was rather annoying.. in my old mr2 I could redline in all gears and maintain max boost..
it just feels like i've got a fuel cut which is kicking in for a few seconds when I hit max boost.. am I right?
Hard to diagnose without a roadtest , if you get stuck drop by im in newhaven , 07973 422272
dude
Hey Roy, i am hopeless with names, sorry I couldn't remember yours!
Hope you got your EGT gauge sorted out Roy! it funny seeing you squirm when the Ferrari engineer started drilling down on your manifold :D
Cheers dude I may just do that, I'll give you a bell in the next couple of days..
I had a quick drive during my lunch hour to see when the boost drops, it drops in every gear when it reaches 4k rpm and the second turbo never kicks in..
I have noticed that there might be a missing relay in the ABS Trac box in the engine bay on the driver side..
There are only 2 relays in there, both appear to be for the ABS...
Another thing i have noticed is the dash "Slip Off" light never comes on when you press the traction controll button.. could this be the problem?
or could the wastegate for the 2nd turbo be stuck open?
The 1st turbo is definitely working!
Cheers James..
07966 245296
Had a similar problem recently when a pipe came off. It was one of the pipes that controls the second turbo ....... or at least i think it was as my symtoms were the same as yours. Second turbo I think it the front one check that all the pipes are on and not leaking
Hey i hope not barry!! the supra has only done 21000 miles and the original owner had a turbo timer..
cheers cashpoint, i'll check the pipes later, i had a look earlier didnt see anything wrong or unusual apart from the missing traction control relay
I definitely do not think it is a blown turbo for a Supra that has only done 20k miles. I am sure you'd see it pissing blue smoke out the exhaust..
The 1st turbo whistles it definitely doesn't whine.. I am wondering if it has anything to do with the fact the traction control is missing, or I have heard that the supra fuel pump operates in two modes, cruise and for heavy loads.. I wonder if it is stuck in cruise mode?
or could the waste gate be stuck open on the 2nd turbo?
Keep your ideas coming in, I am open to suggestions..
You will probably see me at Petes event at Coventry this Saturday, doubt my supra will be fit for the rolling road tho!
Cheers,
James
  • 1 year later...
I think its more likely some problem with Traction control thing.
I got the same car - RZ-S, VVTi, year 2000, manual.
Last summer when I had accident and the TC suffered a bit - my car wouldnt go into high boost at all and the slip control will come on showing the sign that car is sliding (even if the roads dry and I only in 3-4 gear). But when I push the button 'off for TC the car was flying.
U prob need to get a good mechanic look at it.
I overcame that problem by installing RaceLogic TC.
