nige Posted February 17, 2006 Share Posted February 17, 2006 any of you guys used hammerite smooth paint on your hubs/calipers,thinking about tidy'ing them up but i'am not sure if it will take the heat,cheers. Link to comment Share on other sites More sharing options...
ChrisSZ Posted February 17, 2006 Share Posted February 17, 2006 I've used it on the rear hubs in the past with no ill effects - I have also known people to use it on callipers without problems:) Link to comment Share on other sites More sharing options...
letmeshowyou Posted February 17, 2006 Share Posted February 17, 2006 yeah I've used this alot in the past. Works very well. Switched to engine paint for the last time I did it tho and worked even better! Link to comment Share on other sites More sharing options...
Paul Posted February 17, 2006 Share Posted February 17, 2006 Used the gold colour on my MR2 and it worked well and lasted:) Link to comment Share on other sites More sharing options...
stt Posted February 17, 2006 Share Posted February 17, 2006 Put red hammerite on the disc centres and the calipers of my old car,It had green stuff pads of which the paint was supposed to withstand temperatures of 600 degrees.....That promptly came off but the calipers good fandango! Link to comment Share on other sites More sharing options...
TT-DEK Posted February 18, 2006 Share Posted February 18, 2006 I used this on my caliper a few weeks ago, and looks ok. Finished off with decals?. look ok really. (Smooth Gold as well). Theres pickies on suprs chat a few pages down asking honest opinions? take a look. it shows the calipers. Link to comment Share on other sites More sharing options...
black cat Posted February 18, 2006 Share Posted February 18, 2006 ive always used hammerite, never had a problem. rub down with wet and dry and get as smooth as poss. spend more time doing this and a flat smooth will come out perfect. dont rush it. however in this temp its almost too gluepy......... take car out for a run and warm things up a tad. not too hot mind or .......... Link to comment Share on other sites More sharing options...
Barney Posted February 18, 2006 Share Posted February 18, 2006 Have Hammerite smooth on my hubs, getting on for 3 years and no problems. Just make sure you clean and sand properly. Link to comment Share on other sites More sharing options...
black cat Posted February 18, 2006 Share Posted February 18, 2006 ive found the best paint for the hub is halfords own 500 deg silver spray. mask where the pads are gona hit the disk and give the whole disk 3 coats. Link to comment Share on other sites More sharing options...
nickyboy Posted February 19, 2006 Share Posted February 19, 2006 Hammerite smooth on my hubs - makes them look a lot cleaner. Get yourself a wire brush before you get started though!! Link to comment Share on other sites More sharing options...
mr keef Posted February 19, 2006 Share Posted February 19, 2006 so basically everythings alright with hammerite on iron on iron!!!stick it on ya drain pipe alright! Link to comment Share on other sites More sharing options...
