HELP hissing sound when engine is running
ardasaliah
Hi - just your thoughts pls.
There is a hissing sound coming from the circled area. Is this normal. Can someone just have a check on their engine as this sound has always been present on mine. The stock boost is 0.6ish bar when boost controller is off -which I know is a little low. boost gauge on idle is -0.55 bar?
Right- looked and found no split pipes anywhere. tested them all with a foot pump to make sure.
Will the idle negative boost show up a boost leak. Mine is sitting at -0.55 bar. Is this about right- what do other peoples negative boost read? just to compare
Cheers
I don't think you do, BUT the thing to test is what vac you get when you lift off...should head to -.7-.9 and what boost you get 0.8bar on a stocker.
Def get about -.7-9 when i lift off. However the max boost is 0.65bar. Both turbos come on as they should too. I have converted to TTC and the boost was the same. Could be a blocked Cat or something.
I am able to raise the boost with a contoller to 0.8 bar but I would not go past this as I have both Cats still in so not a good idea.
