aiming to be bullet-proof ...
Roy
evening guys - am coming to the end of a self-imposed 3 mth ban on spending any dosh on the supe (having spent a fair packet by my standards!:( already) and am looking for as much reliability as possible from the beast.
i have the current mods so far (engine-wise) : hks type S i/c, 264 in/ex cams +gears, walbro pump, FCD/SLD, FSE, UK spec discs, blitz SUS induction, downpipe, hiper exhaust, blitz BC, racelogic TC, turbo silicone hose kit and i/c + rad hardpipes plus other bits n bobs like hks tt, braided brake and fuel hoses, s40i sparkies, defi gauges etc etc.
i have the following coming in : new rad, safc 2, erl WI kit and a hks sqv bov. i have also been thinking of the following - bigger injectors, fuel rail, hks DLI, underdrive pulley (if applicable?) and i suppose ultimately a single or hybrid set-up :)
i am trying to lay the groundwork for reliable power so what else do i need to consider / purchase ie oil/tranny coolers? proper air ducting? nose-cone? spark leads? undertray? does any of it have to be done in any particualr order ?
any thoughts/suggestions would be most welcome - thanks...
Bigger fuel system is defo next for you.
This could take about £6-800 to complete - how much more do you intend to spend this go? bigger injectors could up the price UK 550's to aftermarket 680's should suffice.
The fuel rail is not a priority unless you go mad :)
not overly mad but i guess 600-ish cc sized side-feeds would do it but i take your point about the fueling - doh, how did i miss that! i haven't budgeted the dosh yet but am looking to do things in stages (hence the order of mods question) so as to spare the wallet too much grief ... :p
alex - thats what i was led to believe as well hence the look-out for side-feeds ... which should fit the stock item unless i am mistaken?
i am more worried about the engine not having an excuse not to perform within it's optimum parameters thats why i was wondering about things like oil n tranny coolers ... if that makes sense. :)
