jagman Posted August 27, 2003 Share Posted August 27, 2003 did an oil change today, on removing the plastic tray, a heavy lump of steel fell out..... on close inspection, the outer ring of the crankshaft pulley had separated the belt tensioner had pulled the belt onto the remaining rubber inner and still worked! how lucky is that?..... Link to comment Share on other sites More sharing options...
Terminator Posted August 27, 2003 Share Posted August 27, 2003 :eek: YLSOB:p Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 27, 2003 Share Posted August 27, 2003 That was probably engineered in by Toyota They think of everything these days! Gaz. Link to comment Share on other sites More sharing options...
Rob Posted August 27, 2003 Share Posted August 27, 2003 Mine separated as I entered a roundabout, that was a thrilling moment I can tell you. Have you had the belt, or cambelt changed in the last few months? Link to comment Share on other sites More sharing options...
jagman Posted August 27, 2003 Author Share Posted August 27, 2003 yes had a new belt 2 months ago, i guess they used prybar to lever the fan belt on .. Link to comment Share on other sites More sharing options...
Rob Posted August 27, 2003 Share Posted August 27, 2003 AHA, nope, it will have been a blowtorch to heat up the pulley nut. I posted about this a while ago. The heat knackers the rubber damper, causing it to eventually shear off. My garage warned me I might need a new pulley at £180 ish, but later told me it was fine. It came off later of course, as posted above. I paid for a new pulley, but sucessfully argued not to pay the labour, as they shouldn't have advised me it was OK at the time. The manager said he would advise Toyota of the risk of using the blowtorch technique. The pessimist in me says its only a matter of time before someone has an accident. I managed to control mine, but to suddenly lose PS as you enter a roundabout is quite dodgy. Link to comment Share on other sites More sharing options...
dude Posted August 27, 2003 Share Posted August 27, 2003 Originally posted by Rob AHA, nope, it will have been a blowtorch to heat up the pulley nut. I posted about this a while ago. The heat knackers the rubber damper, causing it to eventually shear off. My garage warned me I might need a new pulley at £180 ish, but later told me it was fine. It came off later of course, as posted above. I paid for a new pulley, but sucessfully argued not to pay the labour, as they shouldn't have advised me it was OK at the time. The manager said he would advise Toyota of the risk of using the blowtorch technique. The pessimist in me says its only a matter of time before someone has an accident. I managed to control mine, but to suddenly lose PS as you enter a roundabout is quite dodgy. There are more and more cases of these pulleys failing and not because of blowtorches etc , its worth thinking about replacing them when you do the cambelt , im going for an aftermarket like a fluid damper , this is becoming a prob. in the states where there are far more of these cars . John:flame Dev Link to comment Share on other sites More sharing options...
dude Posted August 27, 2003 Share Posted August 27, 2003 BTW if anyone put a blowtorch near my pulley i would pull their nuts off :p john:flame Dev Link to comment Share on other sites More sharing options...
400BHP Posted August 27, 2003 Share Posted August 27, 2003 Originally posted by dude BTW if anyone put a blowtorch near my pulley i would pull their nuts off :p john:flame Dev Make sure they put the torch down first though eh?? Where do you get these aftermarket jobbies from then John? Link to comment Share on other sites More sharing options...
dude Posted August 27, 2003 Share Posted August 27, 2003 A company in the states , Fluidine is who ive allways used before (you need them when your drag racing and run under a set time ) . Terry S has one but i dont know what make it is , hes the one who told me about all the failiures , you can PM terry and see which he is running , these are not underdrive pulleys these are balancers that im talking about . John:flame Dev Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 27, 2003 Share Posted August 27, 2003 Dude, Is it a Dynamic/Harmonic Balancer, we've had one custom made for the RB26DETT, they are about £800 and the HKS version is £1800... It becomes very weak (the stock version) at about 8 grand on the GTR and we all know how many revs they can take... They are required when a car runs 10.99s or less. Gaz. Link to comment Share on other sites More sharing options...
dude Posted August 27, 2003 Share Posted August 27, 2003 Originally posted by Gaz Walker Dude, Is it a Dynamic/Harmonic Balancer, we've had one custom made for the RB26DETT, they are about £800 and the HKS version is £1800... It becomes very weak (the stock version) at about 8 grand on the GTR and we all know how many revs they can take... They are required when a car runs 10.99s or less. Gaz. Thats it dude , i had one on my Zodiac , allways used a company called Fluidyne , they dont use rubber the dampers have a viscous liquid in them , im gonna check with Terry (aka the cab driver) to see what hes running . john:flame Dev Gaz did you get my PM???????????????? Link to comment Share on other sites More sharing options...
Gaz Walker Posted August 27, 2003 Share Posted August 27, 2003 Originally posted by dude Thats it dude , i had one on my Zodiac , allways used a company called Fluidyne , they dont use rubber the dampers have a viscous liquid in them , im gonna check with Terry (aka the cab driver) to see what hes running . john:flame Dev Gaz did you get my PM???????????????? John, Yeah sometimes they are called Dynamic Fluid Balancer too cos of the liquid... I got your PM, just replying Gaz. Link to comment Share on other sites More sharing options...
