suprasport Posted December 31, 2005 Share Posted December 31, 2005 right gonna list the problems then hopefully someone will give an opinion. going to see chris wilson eventually but might not be for a few weeks yet. they may or may not be related engine has overheated twice through airlock but that is sorted now 1] losing water through expansion tank dripping, heating/cooling is fine, maybe juat rad cap [already ordered] 2] tapping/ticking noise from top of engine, only cold/cool, when turned over, goes when warmed up, or revved. used 10w 40 fully synthetic also noticed very small amounts of black specs [not gritty] in top but could be some muck got in whilst doing all the work 3] very very strong smell of either exhaust gases or petrol from oil filler cap, can't tell which the smell is because it is so strong it burns my nose there is a small leak on decat that i need to sort, and hard to say but maybe a small hiss on inlet manifold area, but could be anything very faint so hard to hear properly, but apart from that there is nothing obviously wrong. compression test was good. new parts ignition wise, plugs clean. done all the searches i can think of but found nothing relating to these problems anybody got any ideas from the above especially the smell from oil cap :help: Link to comment Share on other sites More sharing options...
Steve W Posted December 31, 2005 Share Posted December 31, 2005 Do you change the oil 'fairly' regularly Mate ?? Burnt oil smells AWFUL in the rocker cover - the less often you change it .... ? Has a very ACRID smell ? [NOT trying to tell ya the obvious...honest ! just asking] Tapping when cold / goes as warms.... COULD be just tappets (not disastrous, but not cheap either ?) FatS Link to comment Share on other sites More sharing options...
suprasport Posted December 31, 2005 Author Share Posted December 31, 2005 thanks for reply steve, only just changed oil though mate, done less than 150 miles, just been looking on the net and i am concerned now that it is piston, stem seals etc. never really got into engine internals so not sure, but wouldn't problems like that show up on compression test?? the tapping i have always had so not to concerned unless its related. just seems to be noticeable more, i have done a lot of work on car (5 weeks worth) and its starting to p*ss me off now. wanted it perfect to top it off some bas**rds have ran into it once at the back and today down the side, didn't see either ah well.. Link to comment Share on other sites More sharing options...
Steve W Posted December 31, 2005 Share Posted December 31, 2005 no, i meant do you change it at least every 6 months/6,000 etc ? Once it's burnt/old it needs a couple of changes/flushing etc. to get rid of the 'old'/burnt smell. OR, is the smell more 'exhaustie' than just burnt (its a distinct ACIDie smell - horrrible, but not really like exhausts ?) in which case could be right, maybe valve guides etc bypassing fumes (do rings pressurise back up the oilways to the rocker ?? not sure ?) FatS. Link to comment Share on other sites More sharing options...
suprasport Posted December 31, 2005 Author Share Posted December 31, 2005 with you now, yes do change oil every 6 months at longest, i know the smell you mean but definately petrol or exhaust fumes smell. not sure myself about the other part, hoping someone will step in with an answer found this somewhere on net Low Oil Pressure Art Isaacs Low oil pressure can be caused by a number of things including cracked or blown piston rings that allow exhaust gasses to blow by and mingle with the oil in the sump. This thinned (and ruined) the oil and can cause oil pressure to drop off rapidly. A compression test is always a good idea. Just like a physical, you should maintain a record of the compression yearly. It gives you a measure of internal wear. Some points that might also help you identify this as a problem: - The oil smells of fuel or exhaust.- It gets discolored quickly. - You usually get excessive oil mist and leakage around the breather from the excess pressure in the crankcase. In the extreme, oil can come out of the dipstick tube or main seals. - The spark plugs are wet or discolored from oil. - The car can even be smoking from burning oil, which is getting into the intake through the crankcase vent/PCV valve (depending on how your car is equipped) or blow-by of the worn/damaged rings on the intake stroke. QUOTE] Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 31, 2005 Share Posted December 31, 2005 Sounds more like piston ring blow by. If it's been cooked it could have killed the ring tension or worse. A leakdown test might be more appropriate. Fear not, I have a mint, superb, as new N/A engine here, and for sale! Link to comment Share on other sites More sharing options...
bedlam Posted December 31, 2005 Share Posted December 31, 2005 Yep sounds like rings and i just came back from the mates car and he has this exact symptom, oil is stinking of petrol so leakdown test tuesday . Andy Link to comment Share on other sites More sharing options...
suprasport Posted January 1, 2006 Author Share Posted January 1, 2006 i'll wake up from this nightmare soon Fear not, I have a mint, superb, as new N/A engine here, and for sale! f**k happy new f*********g year Link to comment Share on other sites More sharing options...
suprasport Posted January 1, 2006 Author Share Posted January 1, 2006 how much are we talking about chris/anyone ? Link to comment Share on other sites More sharing options...
suprasport Posted January 1, 2006 Author Share Posted January 1, 2006 disater. right dripping has stopped but water is going, steam from exhaust only when warm, white gunk on oil filler cap, oil gone, oil black. smell in oil not as strong now. i know, but someone confirm with all possibilities and costs etc. please just want to get rid of it and get a bike (pushbike) Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted January 1, 2006 Share Posted January 1, 2006 PM'd Link to comment Share on other sites More sharing options...
suprasport Posted January 1, 2006 Author Share Posted January 1, 2006 PM'd cheers james pm'd whats with everyone else keeping quite, was it something i said. been for a good run in it, oil level ok, oil ok, half pint of water gone, no steam/smoke at all hot or cold. seems heavy on petrol gauge though maybe fairies have been Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted January 1, 2006 Share Posted January 1, 2006 Pm'd back Link to comment Share on other sites More sharing options...
