Spark plug reading
carl0s
Can anyone please tell me.. how do these look? They've been in the car (a UK spec BPU) for a slightly extended period.
I'm presuming number 6 is closest to the bulkhead, and number 1 nearest the front bumper.
http://www.css-networks.com/plugs.jpg
You can't really read anything off of spark plugs in use in an unleaded petrol engine...all you can tell is that it's not overfueling to the point of clogging the spark plugs up.
Though what the hell is a BKR7EVX??
Anyone?
BKR7E (6097's) should be used, normally, are these special in someway?
Guest chiefvinso
The tip of no 1 looks bent over, was this after you pulled it out? Otherwise they all look pretty clean, however were they all put in at the same time? How long have they been in 15,000miles?
Spark plug reading (for turbos) is only ever useful if something is waaaaaay off inside the engine, by which time you'd know about it already.
N/A engines are easier to troubleshoot as you can switch them off at full throttle and read the plugs.
With wideband and EGT displays this is now becoming a lost art (if it ever *was* an art)
They are what Pete Betts recommended more than once, and seem to have run the car very well for the last year!
I did however read that you said for some reason platinum-tipped wasn't a good idea.
Anyway, they are BKR7 'E' I think means platinum centre-electrode and VX means it is the very fine VX tip.
Actually slightly more than 15k. I must have bent no1 on removal as I checked them with my torch as soon as they came out and I'm sure I'd've noticed that. They did all go in at the same time.
Well I guess it shows that I haven't had any catastrophic detonation, but I didn't really need any help in seeing that.
I've got to fit a wideband some day soon..
