Mcgoo Posted December 11, 2005 Share Posted December 11, 2005 Since this cold spell has kicked in I'm getting a bit of a squeal coming from the drive belt area. Not every day mind you. I thought it might need replacing but just checked the tensioner lines and seems ok ( just to the right of the middle line) Any ideas? Link to comment Share on other sites More sharing options...
DShox Posted December 11, 2005 Share Posted December 11, 2005 i think the squeals could be a fan belt in need of tightening or your water pump. Link to comment Share on other sites More sharing options...
b_have Posted December 11, 2005 Share Posted December 11, 2005 Most probably the belt tensioner bearing. Anyone have a proceedure for replacing that, and Bearing required? (I believe its not listed as a serviceable part, but remember someone doing it) Link to comment Share on other sites More sharing options...
absz Posted December 11, 2005 Share Posted December 11, 2005 very common on worn belts. you will find that the belt will have cracks along the inside facing. just replace it with a new one Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted December 11, 2005 Share Posted December 11, 2005 very common on worn belts. you will find that the belt will have cracks along the inside facing. just replace it with a new one Link to comment Share on other sites More sharing options...
