Grinding noise
Guest jflow78
Guest jflow78
Whilst driving i can feel a slight grinding in the pedals and here a wherring noise i can also feel it through the steering wheel ever so slightly it happens more when i turn, it comes defintly from the front of the car almost like its in the wheel area. when i drive past cars or walls i then here a shatering noise echoing of the deflection Noises are hard to explain.
Does anyone know what this could be
Guest jflow78
Ended up being that the wheel bearings are screwed, does anyone know what would happen if i was to keep driving with bearings like this and if this is common with these cars
Guest jflow78
I was told that i have to replace the hubs and seals as well is this right.
And because all supra's are J spec imports in Aus you can only get them from Toyota dealers whom order from Japan and charge a packet (AUS$1780 just for the parts), the lexus ls400 also use the same bearings and stuff as the supra
