2JG Posted November 17, 2005 Share Posted November 17, 2005 Can anyone help me out?? I have a '96 n/a facelift supra and I need to replace the exhaust on it (cat back). I have been told that a TT cat back exhaust system will bolt straight on. I ordered my new exhaust only to discover that it was too big! The problem I have is that the current exhaust pipe diameter is 70mm (external) and this connects to a 65mm (external) cat converter pipe. Has anyone else come across this problem with their n/a supra or am I just being stupid?? Link to comment Share on other sites More sharing options...
Digsy Posted November 17, 2005 Share Posted November 17, 2005 The pipe diameters are certainly different between NA and TT, but I believe (may be wrong) that if you had the cat in place it would still bolt straight on. I once tried to fit a TT exhaust to my NA and the gasket and joint to the main cat was the same even though the downstream pipe diameters and the joint / gasket diameters between the centre section and back box were definately different. Link to comment Share on other sites More sharing options...
