camber
suprasport
just fitted springs and new wheels
took it to be aligned at ATS (good set of lads) said alignment was only out by 1mm so not worth bothering with.
but camber as i allready new is a mile out -3 or 4 degrees, but they dont do that told me to use a spirit level and guess, that cant be right surely its more precise than that
think it is -1.5 camber, tried moving the cams but they are solid
any comments appreciated
yeah to right, just meant they were polite
they did the toe and said 1mm out. thought it was supposed to be exact
known camber was out since ripping my hands to bits taking wheel off.
pulled it off road for now
not going anywhere http://www.mkivsupra.net/vbb/showthread.php?t=51799
all they have done by the sounds of things is line your front wheels up in relation to the rears which will also be out as you've just lowered it. the four wheel alignment does each corner independently
will ask around for someone reputable ready for it being back on the road,
a local garage did it as well, paid them but as a favour only charged me for front as i had bought tyres off them
wasn't till i got home that i realised they hadn,t charged because they hadnt done
thanks chris,
its off road for a while, but i am going to get it something like for now then will get in touch and have a run over to you, few things i wanted to ask you about anyway
no one i would rather set it up than yourself
quick question though...... cam bolts on lower arm. is one a locking nut? they are solid both sides. wd40'd them to soak
