Aerotop Dave Posted November 10, 2005 Share Posted November 10, 2005 Got a slow puncture in my Goodyear F1 - replace the tyre or get it repaired? I'm a bit wary of repairs, but is this view justified or is repairing actually quite alright? Link to comment Share on other sites More sharing options...
Marco Posted November 10, 2005 Share Posted November 10, 2005 I had one of my tires repaired after Bovindon, and it was just fine Link to comment Share on other sites More sharing options...
RICHARDA Posted November 10, 2005 Share Posted November 10, 2005 Depends whereabouts on the tyre it is punctured, if its across the 3/4 width of the tread then you are generally OK, dependant on overall width of tyre. If its on or near the sidewall its classed as a major repair and is prbably not worth it. Alternatively could be a valve leak or bead leak. Your local KW should charge around £18 for the repair which would include new valve and balance, however slip the guy a tenner cash and everyones a winner;)  HTH Rich Link to comment Share on other sites More sharing options...
Ian W Posted November 10, 2005 Share Posted November 10, 2005 front or rear tyre mate? where is the puncture on the tyre itself? Link to comment Share on other sites More sharing options...
Pete Posted November 10, 2005 Share Posted November 10, 2005 Repairs are ok in my experience as long as in the middle 2/3rds of the tyre. Link to comment Share on other sites More sharing options...
Ian W Posted November 10, 2005 Share Posted November 10, 2005 damn you RichardA.........just too quick for me (no jokes about you having a TT and me having an NA either!!) Link to comment Share on other sites More sharing options...
DamanC Posted November 10, 2005 Share Posted November 10, 2005 Repairs are ok in my experience as long as in the middle 2/3rds of the tyre. Link to comment Share on other sites More sharing options...
Aerotop Dave Posted November 10, 2005 Author Share Posted November 10, 2005 front or rear tyre mate? where is the puncture on the tyre itself? It's left rear.  Not sure where it is actually, it's very slow though. Must have happened last night as it was flat this morning but not totally pancake. Phoned local ATS place and they too said about the 'depends where it is' bit, so I guess I'll take a trip down and see what they say. £180 for a new one though. I thought they were meant to be £120 or something for Eagle F1s. The sooner I sell the darn thing the better. Link to comment Share on other sites More sharing options...
Digsy Posted November 10, 2005 Share Posted November 10, 2005 Repairs are fine if done properly. Link to comment Share on other sites More sharing options...
tbourner Posted November 10, 2005 Share Posted November 10, 2005 My repair is fine, I was advised to replace it if I get a second puncture on the same tyre though. Link to comment Share on other sites More sharing options...
monkey3 Posted November 10, 2005 Share Posted November 10, 2005 I've had a few repaired over the years and again providing it's in the middle bit of the tire, they're normally fine. One bit of advice though... don't, whatever you do, use tyre weld or anything of that calibre as nowhere will repair it afterwards. I had a new tyre on my old beema and that got a big nail through it. Went to the tyre place was told they wouldn't repair it, so I called another one, told the same. So I had to go get my use out of it. Up in smoke it went, one wheel (the crap one) on dry tarmac and the other on a carefully prepared section of wet leaves and mud and mush. Down to the wire! Link to comment Share on other sites More sharing options...
Pete Posted November 10, 2005 Share Posted November 10, 2005 Problem is if you decide to replace, then you ideally want to replace both sides to retain even wear/handling etc depnding on the current wear of the tyres of course. Very expensive then. Link to comment Share on other sites More sharing options...
toyotasuprauk Posted November 10, 2005 Share Posted November 10, 2005 I think repairs are fine, I had it done on one of my cars tyres once. Thankfully only once as I thought it was pretty expensive. If it was considered slightly dangerous in any way I dont think it would be allowed. Link to comment Share on other sites More sharing options...
JohnK Posted November 10, 2005 Share Posted November 10, 2005 As has been said, if its in the tread a repair done properly is fine, I have one in one of my rears, did well over 150mph in Germany on it and im still alive Link to comment Share on other sites More sharing options...
Aerotop Dave Posted November 12, 2005 Author Share Posted November 12, 2005 Cool, £15 repair. Sorted Link to comment Share on other sites More sharing options...
