cusco brake stop
uk-rich
I don't think bulkehead flex is an issue with the MKIV, unlike with Skylines. That's the GOOD side of a heavycar, extra metal where it often matters :) So no, I doubt you'd notice any difference. Press the brake pedal as hard as you would normally to slow up to the point of the ABS kicking in whilst someone looks to see if the servo and master cylinder move. If they do a stop against the end of the master cylinder may remove some pedal travel and add feel.
