Help with catalytic converter
Foxx
  • 3 weeks later...
Sorry, that question was a bit vague.
Having emissions trouble at mot on a TT vvti (this cat plus second cat fitted) with very high CO 8% Vs 0.3 limit. Guessing this is an O2 sensor from the search.
I have the part number (89465-19725) but can only find parts from japan. Is that the only option now?
Any other known issues that cause this id appreciate you letting me know. Many thanks
Edited by Foxx (see edit history)
Not a pro but looking at those readings you've something really wrong as they're way out. Too much for just a cat imo, car running very rich so you o2 sensor is a good shout and you'd probably get one from Rock Auto in the US quicker. Also is that oil temp reading at the end right, if it is an Apexi cat its probably a sports cat that needs to be roasted to work.
Thank you for this.
I tried rock auto. the latest supra I could select was 1998 and it has us/cad flags next to it. I guess that downstream/upstream (see pics) means these ones are for cars with 2 sensors so probably aren't correct. I couldn't find any others for a vvti even with searching the OEM part number.
Any other help appreciated.
