1994 NA-T mk4 supra black
Harleyt1993
 Share
Harley Spec List-
220,000km on shell
originally an NA auto
-408HP @ Flywheel(Power Limited by Gearbox) @ 0.6 Bar Boost
Engine/Performance:
-Unopened 2JZ-GE VVTi from a Gs300 75k miles approx
-Custom/modified Engine Loom
-Bosch 550cc Injectors
-New OEM Toyota Crank Pulley
-Engine Fully re-sealed at build
-XS Power Turbo Manifold and Turbo. De-Slagged Manifold
-Custom Fabricated Turbo Support
-Modified SRD Turbo Oil Drain
-SRD Matrix Hose Kit
-60mm Turbosmart wastegate with Screamer Pipe
-Pro FMIC Intake Manifold & Fuel Rail
-RRS Custom Throttle Cable for FFIM
-Aeromotive Fuel Pressure Regulator and AN6 Braided Lines
-Aeromotive Fuel Pump
-XS Power 3" Intercooler
-Custom Aluminium Tig-Welded Boost Piping
Management;
-Syvecs S6GP ECU
-NTK Lambda Sensor, Bosch Combined Oil Pressure/Temp Sensor, Link MAP Sensor, Bosch Knock Sensor, Link Intake Air Temp Sensor, Mac Boost Solenoid
-Syvecs Calibration Switch for Map Selection
Drivetrain;
-W58 Gearbox(Conversion from Auto)
-Competition 6-Paddle Clutch
Brakes;
-UK Spec Brakes all round
Suspension;
-Tein Coilovers with EDFC
Interior:
-Recaro treadline seats from mk6 Honda accord
-Aftermarket steering wheel
Exterior:
-polyurethane front lip
-enkie rp01 wheels
-ridox rep side skirts
-ridox rep rear spats
Exhaust;
-3" titanium Catback Exhaust. Unsure on brand?
Miscellaneous;
-Relocated Power Steering Reservoir
-Battery Relocated to boot
-Shine Auto Replica Diffuser
Built By James @ Retro Roadsports
Mapped By Mike @ SRD Tuning
bad points
-needs painting as the paint has seen batter says
-slight surface rust around left side of rear window
-slight rust on rear sills
asking £25,000 Ono
text me rather than calling
07539527400
  • Like 2
 Share
