Putting my na -t up :-(
sidewaysdan
 Share
Hi guys and girls.
so after 8 years of mostly sitting in a nice garage it’s time to let it go.
Just a quick insight to my car . Been a member since 2008 and this is my 2nd supra and had it since 2015
Thanks Dan
£30k
ENGINE.
2jz-ge
compression lowered to 9.5-1
TT head gasket
630cc seimens dekka injectors
t61 trubo .70/.68
60mm Demon tweeks external wastegate .
Strengthen Xs-power manifold.
Auto barn front mount intercooler with custom 2.5”hard pipe kit.
New walbro 225 fuel pump with uk spec fuel pump ecu
4 runner distributor
twin elec fans wired to switch
greddy emu mapped to 1.2bar
mapped by Lyndon (nodalmighty)
Engine was refreshed by dr-j @ rocket dog racing .
Acl race bearing. All new oe gaskets
New rings engine probably done less that 3.5k miles.
TRANSMITION
the excellent david p hybrid auto
pressure switch at max
fully shimmed valve bodies
a01 diferential
SRD Twin oil coolers
OTHER
JR10 alloy wheels now refurbished in gloss black less that 100 mls
front 8.5x18 Toyo proxes t1 235/45/18
rear 9.5x18 achillies 275/40/18 all done less than 100mls
j spec m-tech front drilled and grooved disc new .less than 100mls on them
UK glass headlights
TRD spoiler with carbon blade and end caps.
stock spoiler
Suspension
Tein super street coilovers .
All new drop links
Inside
Recaro speed replicas from whifbitzo
As new
Defi oil temp,oil pressure,water gauges with defi controller in carbon glove box .
Aem tru-boost.
APR aft gauge
Had the front main seal and cam cover gaskets done.
Front and rear bushes and drop links .
Also just fitted a new alternator
Car was re sprayed by Dr j when he had it. I’ve had a stage 2 polish and it’s come up lovely.
Parts to go with
3” exhaust
Xs-power ffic
Stock spoiler
AET BW s364sxe
ecu master black with plug + play harness for a NA-T
tt front intake welded to na lower runners . For na.
Oil changed pretty much every 250mls or so . As I get bored and want something to do
Edited by sidewaysdan (see edit history)
 Share
