Supra-love Posted January 12, 2021 Share Posted January 12, 2021 Just wondering what size the water feed/return should be from a single turbo? Im looking to use 5/8” reinforced diameter hose. Just want to make sure this is the best size to use for turbo water feeding/returning. Water feed will come from the water pump nipple and return to the upper radiator water neck. The oil feed will be -4 and will have a 1mm restrictor following the turbos recommendation. oil return will be 10an to sump Link to comment Share on other sites More sharing options...
baldy Posted January 12, 2021 Share Posted January 12, 2021 I've used an8 water lines on mine Link to comment Share on other sites More sharing options...
Supra-love Posted January 12, 2021 Author Share Posted January 12, 2021 34 minutes ago, baldy said: I've used an8 water lines on mine Did you connect from the water pump and top water neck too? wondered what size they are, assume your an8 is the correct size for them? Link to comment Share on other sites More sharing options...
baldy Posted January 12, 2021 Share Posted January 12, 2021 I fed the turbo and wastegate from the pipe that runs aalong the side of the block and returned to the water neck 1 Link to comment Share on other sites More sharing options...
