Supersupra1 Posted August 7, 2019 Share Posted August 7, 2019 (edited) Hi all, Started the car up yesterday and its developed this intermittent squeak on idle which increases with higher revs. Interestingly enough, the last time it was driven, it was over several speed bumps just before it was parked up. Not sure if they could have knocked something out of alignment. No mechanic has looked at it yet, i thought id pose the question on here for you veteran enthusiasts first so i don't look like a total newb if/ when i take it in Thanks in advance Edited August 7, 2019 by Supersupra1 (see edit history) Link to comment Share on other sites More sharing options...
Scooter Posted August 7, 2019 Share Posted August 7, 2019 Have a read of this, it's a good first thing to check - the crank pulley possibly delaminating http://www.mkivsupra.net/vbb/showthread.php?286491-Power-Steering-Pump-problem-Crank-pulley-problem/page2&highlight=tippex Link to comment Share on other sites More sharing options...
Supersupra1 Posted August 7, 2019 Author Share Posted August 7, 2019 Update: started her up again, same squeak on idle, increased inline with revs. Turned it off then back on, squeak stopped but it was followed by some worrying grumbling. Turned it off, someone is coming tomorrow. Will upload results. Link to comment Share on other sites More sharing options...
Scooter Posted August 7, 2019 Share Posted August 7, 2019 Possibly just one of the pulleys on the belt run, the bearings can go on the tensioner or alternator etc and give noises, hope it's a simple and inexpensive fix. Link to comment Share on other sites More sharing options...
PJJ Posted August 8, 2019 Share Posted August 8, 2019 Mine was doing a similar thing but noise went away after it was warm. When I got it serviced I asked them to check the crank pulley, and yes mine was slipping slightly so had it replaced on the service. Link to comment Share on other sites More sharing options...
Tommyd16 Posted August 9, 2019 Share Posted August 9, 2019 I had the same and it was the part below. Easy change and pretty cheap. I would start here http://www.garagewhifbitz.co.uk/toyota/supra/engine-components/pulleys-belts/garage-whifbitz-639.html Link to comment Share on other sites More sharing options...
