Turbo part number?
Houstie999
So Iv found someone to refurbish my turbos but he needs to know the exact turbos my car is running
I’m hoping for at Japanese import, 1996, TT manual 6 speed there’s only one option for turbos 🤞🏼
Can anyone tell me what turbos are on my car?
Thanks for your time
Manufacturer Toyota (Hitachi)
Type CT-20 (PN: 17201-46020 (Front), 17208-46020 (Rear)
Turbine size (Outlet diameter) 48mm
Turbine size (Inlet diameter) 59.8mm
Turbine blade count 10
Turbine material Ceramic
Turbine housing Inlet (ID) 36mm
Turbine housing Outlet (ID) 50.1mm
Turbine shaft Diameter 10mm
Turbine housing A/R .35
Compressor size (Inlet diameter) 37mm
Compressor size (Outlet diameter) 62mm
Compressor blade count 10
Compressor material Aluminium
Compressor housing Inlet (ID) 49.8mm
Compressor housing Outlet (ID) 32.4mm
Compressor housing A/R .36
*Wastegate size (ID) 26mm
Actuator spring rate 10 psi
Bearing ID 10.05mm
Bearing OD 15.9mm
Bearing width 9mm
Bearing material Bronze
Bearing oiling holes (per bearing) 6
Think this is what you will have but can't accept any responsibility if yours is different. I took this data from another site years ago when I was talking to Nerings about replacement cores. Sadly despite an encouraging start they never came through.
