TuneR Posted January 10, 2019 Share Posted January 10, 2019 Quick question about refitting injectors as trying to find where the problem is with my fuel rail and now have a complete spare one. Anyway whats the best way to fit the bottom rubber seal? Put it into the rail and then slide the injector in or place on injector and put it all in together. Pic show one that came out all squashed to injector. Also I got new o-rings but didn't get the rubber vibration seals, they seam to be the same part number for top and bottom of injector. Cheers Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 10, 2019 Share Posted January 10, 2019 Assemble o-rings onto injector, put some lube then slot the injector into the rail. Sometimes need to twist them on the way in for them to slide in correctly. Link to comment Share on other sites More sharing options...
TuneR Posted January 10, 2019 Author Share Posted January 10, 2019 Assemble o-rings onto injector, put some lube then slot the injector into the rail. Sometimes need to twist them on the way in for them to slide in correctly. No special things to do with the vibration ones? Link to comment Share on other sites More sharing options...
