Airbag light with aftermarket wheel
D1andonlyantman
Hi everyone. Ive got an aftermarket steering wheel with no airbag which makes the light stay on. Ive read about jumping a couple of pins under the bonnet, but apparently that stops the passenger bag working too. To keep it all working I'm going to use a resistor so it thinks the bag is still there. I'm reading that 2ohms should do the trick? Will this 2.2ohm resistor across the plug sort it, or does anyone have a better way?
https://www.ebay.co.uk/itm/Airbag-SRS-resistor-warning-light-defeat-1-0-to-8-2-and-2R2-2R7-3R3-packs-of-5pc/111988645691?hash=item1a130b1f3b:m:mE-icP3PDO9fS8ejmpafQtg
Cheers
