oil coolers
coza
Hi
Looking to be going round nurburgring end of June, I went last year and cooked the power steering [sHOCK][/sHOCK] should of read about it first, however this year looking to fit a power steering cooler and oil cooler what do you lot recommend ?
thanks
Summit Racing have a wide range of PS cooler kits and a large amount of oil coolers, failing that you could try SpeedFlow or ThinkAuto.
http://www.speedflowshop.co.uk
http://www.thinkauto.com
https://www.summitracing.com/int/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=power%20steering%20cooler&retaillocation=int
EDIT: check the Summit kits and then build your own from UK supplier ;)
No as car still being built.
But the plan is to put the oil cooler in the exact location the SMIC was and to use the SMIC ducting. It just means I'll have to fabricate some brackets but is ideal location. PS cooler will go on opposite side of car by where the washer bottle lives
Edited by Big Mark (see edit history)
